1 2 [Last >>]
All Forums > Prototypes, Concepts and Electric > Bailey Blade > Post Reply
Post #1 Tue, Dec 11, 12:37 AM
ajzahn
Posts - 62425
Blade Prototype overview:
This car was designed to capture the look and feel of old school automobiles with a hint of modern touches. This is a full performance car built with modern advancements. Big V8 fuel injected power plant up front riding on a tubular hybrid chassis with full independent suspension. The addition of belly pans and rear splitters are added to keep down force up without the need of a giant rear spoiler.
Powertrain:
Engines types range from Roush 400HP to 500+HP. The B1 engine compartment is designed to accommodate most small block engines including the newer ford modular 4.6L engines.
Suspension:
Several suspension types can be applied. Standard equip is a fully adjustable independent rear suspension with adjustable shocks. Front suspension utilizes adjustable upper and lower control arms and with adjustable performance shocks. The rear end can be swapped with a Ford 9" or 8.8" straight axel with 4-Link or 3-Link rear control arms. Also included are adjustable anti-sway bars for both front and rear of the car.
Chassis:
Full steel chassis consisting of tubular roll cage affixed to a solid ridged box steel frame. The tubular roll cage is hidden from view and protects the driver and passenger sides with the addition of two hoop style bars to protect in case of roll over.
Body:
Full Vinyl Ester hand laid fiber glass body that is Light weight in design with functional trunk doors and hood. The hood is a clam shell style hood that flips forward to allow for easy access to the engine compartment.
"BLADE" ProtoType Specifications
Engine ROUSH 353IR 8-Stack Fuel Injected
Horsepower / RPM 480HP @ 6000 RPM
Torque (lb.-ft./N-m) @ engine rpm 460 lb.ft. @ 4200 RPM
Redline (rpm) 6500
Displacement 353 cu. in.
Intake Manifold Weber Style 8-Stack Induction System
Fuel System Electronic Fuel Injection
Vehicle weight WO/Driver 2200 lbs.
Wheelbase 95 in.
Overall length 156 in.
Body width, without mirrors 72 in.
Overall height 45 in.
Front track width 58 in.
Rear track width 59 in.
Brakes
4-wheel disc antilock
Number of pistons front/rear 2/1
Rotor diameter and thickness:Front/Rear 13.0 / 1.02 in. | 12.0 / .65 in.
Steering
power-assisted, variable-effort rack-and-pinion
Ratio 15.6:1
Turns stop-to-stop 2.53
transmission
6-speed Manual / short-throw - T56
Suspension
four-wheel independent includes 6-way double ajustable shocks with ajsutable coilover springs
Axle 411 ratio or 373 ratio - limited-slip
headlamps
Xenon, high-intensity discharge, Projector with CCFL Halo/Angle Eye
Wheels Size
18" x 8.5" front and 19" x 10.0" rear
Tire Size Front 275/35ZR-18 and Rear 325/30ZR-19
Post #2 Tue, Dec 11, 12:40 AM
smellygruby
Supercar Messi - 2358
looks hot
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you, that's the killer."
Post #3 Tue, Dec 11, 5:31 AM
WhiteChocolateWorld
Supercar Messiah - 40519
Straight out of Burnout.
This is for Chris Draper:
A boot for Christmas.
Post #4 Tue, Dec 11, 8:50 AM
Porsche addict
Supercar Messiah - 48888
Speeds 12 meets C3
sixspeedfirebird & Porsche Addict: members of the "Boxy Volvos suck and the F50 kicks the F40's ass" club.
Post #5 Tue, Dec 11, 9:32 AM
tafster
Supercar Messiah - 3446
I don't know why, but I feel like there is a BMW waiting to jump out of that. A Z3. Maybe just the DLO giving me that vibe.
Post #6 Tue, Dec 11, 10:17 AM
Ferrari Addict
Supercar Messi - 3015
Good, but needs different (i.e. "less flashy") wheels.
SHAGOHOD!
Post #7 Tue, Dec 11, 11:44 AM
DerivativeN
Senior Member - 401
This is ugly as sin.
Post #8 Tue, Dec 11, 6:47 PM
Tensor
Supercar Messi - 6845
Quote from DerivativeN
yes.
Looks like it rear ended somebody. The designer tried too hard... it looks like it's trying to compensate for a small penis
Account canceled
Post #9 Tue, Dec 11, 7:22 PM
RLQ
CAUTION - 58501
I kind of like it.
I don't give a crap about whales so go and hug a tree.
Post #10 Sat, Dec 15, 4:03 PM
944turb0
real - 125493
I dig it. Everyone else could shutup.
see that flag in the middle of the 911 wreckage? how is it flapping??
Post #11 Sat, Dec 15, 9:30 PM
CSTUBS
Supercar Messiah - 2415
Quote from 944turb0
its a POS like you
"I call a square a square and a circle a circle so if you act like a #%!@ then I'll call you a #%!@"
Post #12 Sun, Dec 16, 8:55 PM
daisho13
Supercar Messiah - 2868
I kinda like it... it has a retrofied Shelby Series 1 vibe to it that works for me. But hey, maybe I just have a small penis.
http://russellsteapot.com/comics/
Post #13 Mon, Dec 17, 3:20 PM
thunderbunny
Supercar Messiah - 1270
CMG: "Don't hate the player, hate the Earth."
Post #14 Sun, Dec 30, 7:51 AM
Chris Draper
Corvette Guru - 19223
If TVR built a Cobra, that is exaclly what it would look like.
http://corvette-info.tripod.com -
Post #15 Sun, Dec 30, 8:08 AM
944turb0
real - 125493
they should name it something cooler than Blade, blade is for a sleek low car.
it chould be an animal nmame. It should be called the Pahnther or Leopoard or Lyncx or somteing.
Post #16 Sun, Dec 30, 11:10 AM
not exactly teh man
Supercar Messiah - 7736
Quote from 944turb0
She said, "Well daddy if I had nuts under my chin
would those be chin-nuts?"
I said, "Hell no #%!@ you'd have a dick in your mouth!"
Post #17 Sun, Dec 30, 2:06 PM
bananatucker
Supercar Messiah - 13007
Quote from 944turb0
Panthor!
nine44turb0: i wanan toss paper airpalens at a goatse anusnine44turb0: he tries to cathc them like a venus fly trapnine44turb0: if one makes it in he lets go and it slams on it
Post #18 Sat, Jan 5, 10:17 PM
WhiteChocolateWorld
Post #19 Sun, Jan 13, 10:12 PM
torque
Supercar Messiah - 10522
Quote from VICIOUS
Very Americana. They put a lot of classic lines into it.
Badass.
I take a lot of pictures and videos, but that doesn't mean you will see them.
Post #20 Sun, Jan 13, 10:44 PM
Metamorphosis
? - 13464
I dig.
Post #21 Mon, Jan 14, 7:53 PM
gtr427
New User - 26
it looks like a cobra body, but with almost a marcos mantis rear end, a tvr/aston martin-ish front end, bmw side vents, a detomaso pantera-ish hood, rx7 fd3s headlights, and kind of a zagato roof thing going on. it looks cool but the individual features look far to familiar for it to be a super big seller. if it had better taillights and knock off hubs or mag wheels it might be cooler but definitely not in that color of red. the convertible is sweet but it could stand to have a slightly exposed supercharger or something sticking out of the hood at least. i'd buy one in slate gray with black racing stripes
Post #22 Mon, Jan 14, 8:05 PM
gtr427
New User - 26
it looks like a cobra body, but with almost a marcos mantis rear end, a tvr/aston martin-ish front end, bmw side vents, rx7 fd3s headlights, and kind of a zagato roof thing going on. it looks cool but the individual features look far to familiar for it to be a super big seller. if it had better taillights and knock off hubs or mag wheels it might be cooler but definitely not in that color of red. the convertible is sweet but it could stand to have a slightly exposed supercharger or something sticking out of the hood at least. i'd buy one in slate gray with black racing stripes
Post #23 Wed, Jan 16, 5:59 PM
PandaBeat
Supercar Messiah - 91022
Ugly and unoriginal.
Go get #$%#ed by your dog and eat his shit, you pathetic moronic cum guzzling worm
Post #24 Tue, Mar 4, 2:22 PM
stiffstuffW
Supercar Messi - 4699
Quote from smellygruby
looks hot
Post #25 Sun, Jul 27, 6:38 PM
BaileyBlade01
New User - 1
Hello everyone…
I came across this thread about our car… I just wanted to let everyone know that it’s been revised into a new design. We had to do most of these changed to me production regulation regulations.
You can check out the website for more info: www.BaileyBlade.com
Or check out these links of us building designing and building the car on video.
Video 1: Building the Forms for body buck.
http://videos.streetfire.net/video/Building-the-Bailey-Blade_164356.htm
Video 2: Foam Process.
http://videos.streetfire.net/video/Building-the-Bailey-Blade_165381.htm
Video 3: Foaming part 2
http://videos.streetfire.net/video/Building-the-Bailey-Blade_166041.htm
Video 4: Building the Bailey Blade part 4 – Foaming part 3
http://videos.streetfire.net/video/Building-the-Bailey-Blade_166597.htm
Video 5: Building the Bailey Blade part 5 – Foaming part 4
http://videos.streetfire.net/video/Building-the-Bailey-Blade_167005.htm
Video 6: Building the Bailey Blade part 6 – Foaming part 5
http://videos.streetfire.net/video/Building-the-Bailey-Blade_167648.htm
Video 7: Building the Bailey Blade part 7 – Foaming part 6
http://videos.streetfire.net/video/Building-the-Bailey-Blade_169061.htm
Video 8: Building the Bailey Blade part 8 – Foaming part 7
http://videos.streetfire.net/video/Building-the-Bailey-Blade_170328.htm
PS. I can’t seem to register on these forums properly… it never sends a password or info after I sign up. If a moderator is watching maybe you can help… this way I can keep everyone updated on the progress and release date for the car.
Thanks,
- Neal
Posted: Today
Superbot
Posted: Today
Superbot
1 2 [Newer >>]
