All Forums > 2004 Pontiac GTO Ram Air 6 Concept > has anyone figured this motor out? > Post Reply
Post #1 Fri, Nov 5, 12:07 PM
2998ccCSL
Kiwimousekönen! - 23509
ls2, ls7 pick one!!
is anyone sure if its 4.125 bore x 3.650 stroke(3.620?) or 4 x 3.875?
Pametni odneha
Post #2 Fri, Nov 5, 2:57 PM
Falcon1
Senior Member - 213
From what I read in Motortrend.com this is an LS2
When all you have in life is a hammer, everything is a nail
Post #3 Sat, Nov 6, 6:03 PM
Sniperhail
Senior Member - 226
The LS2 in the '05 Vette is a 6 liter, this goat is packing 6.4 liters. This may be the LS7 that'll end up in the new Z06 should it make a reappearance down the line.
Post #4 Sat, Nov 6, 6:37 PM
oddseth
Senior Member - 170
I pretty sure that it is an LS2 motor bored out and tuned. My guess is that Pontiac will release a Judge with this engine and also use it in the C6 Z06. It might be the most cost effective way to make a performance model of the GTO.
Post #5 Sat, Nov 6, 10:03 PM
LRP Gearhead
Senior Member - 191
According to Autoweek, the mill is an amalgam of parts, mostly LS2 and LS7. I also don't think it's got catalytic converters, so good luck seeing a street version post those numbers.
Post #6 Sun, Nov 7, 12:37 PM
mopar119
New Member - 2
THE ENGINE IS A MIX OF THE THREE ENGINES ( LS1 LS2 AND LS7, MOSTLY LS2 AND LS7) WHAT HAPPENED WAS FOR THE SHOW ENNGINERS WENT TO BOTH PRESENT AND FUTURE PARTS BINS TO MAKE THIS CAR. THEY USED THE LS7 BLOCK WHICH IS GOING TO BE THE ENGINE THAT POWERS THE C6 ZO6. VERY LITTLE PIECES ARE USED FROM THE LS1 BUT THE CAM CRANK AND OTHER VITALS ARE FROM THE LS2.
Post #7 Sun, Nov 7, 5:28 PM
2998ccCSL
so its bore is 4.125 and its stroke is 3.620 or something like that?
Pametni odneha
Post #8 Sun, Nov 7, 5:37 PM
thedark1unknown
Supercar Messiah - 2575
so i guess GM got bored so they decided to combine engines and see what the hell theyd get
Now nigger off, you illiterate goddamn ghetto trash can - 426 Hemistage 8
lol... did you just call my dad a scaffold? wtf hahahaha - Wheelman
At petrol stations, people always say to a Ferrari driver, "Ooh, I bet you don't get many miles to the gallon out of that" or "I can get more luggage in my Maestro". But if you have a Lambo, they'll say "My God, it's got orange seats" and "Can we have sex in it?"
Post #9 Mon, Nov 8, 12:47 AM
kuluvu
Member - 63
90 hp/liter ain't bad at all for a pushrod 2 valve lump.
But then again, they didn't disclose how absurdly high the compression ratio is huh.
Post #10 Mon, Nov 8, 7:05 PM
Bugatti4evr
ringleader - 23128
its an LS2
Post #11 Wed, Nov 17, 5:39 PM
dW
New Member - 1
Quote from oddseth
Actually through some oversight on GM's part, the trademark on the name "the Judge" lapsed and is now owned by SLP Engineering.
Post #12 Mon, Nov 27, 5:39 PM
bongburglar
Member - 81
SLP still deals with GM though, so maybe unlke fords big #$%# up with the GT they could actually get the name back.
Posted: Today
Superbot
Posted: Today
Superbot
