Post #1 Wed, Oct 24, 6:54 AM |
jumpman23
Senior Member - 370
MSRP: $99,100
Basic Specs Body style: Coupe Seating capacity: 4 Engine: 5.0L V-10 40 valve DOHC SMPI Engine horsepower: 500hp @ 7,750RPM Engine torque: 383 lb.-ft. @ 6,100RPM Transmission: 6 speed manual Drivetrains: rear-wheel Curb weight: 3,909lbs (1,773kg) Miles per gallon (city/hwy): 12/18
Performance Specs 0-60 mph: 4.6 seconds Lateral acceleration (g): .9 Payload: 941lbs (427kg) Power-to-weight ratio: 7.8 lb/hp
Standard Equipment Highlights
Power and Performance
Engine: 5.0L V-10 40 valve DOHC SMPI Transmission: 7-spd auto-shift manual w/overdrive Drive Type: Rear-wheel drive Axle Ratio: 3.62 axle ratio Exhaust: Stainless steel exhaust Battery: 90 amp hours (Ah) battery Alternator: 170 amp alternator 0-60 mph: 5 seconds 1/4 mile: 13 seconds 111 mph lateral acceleration (g): 1 slalom: 61 mph
Active and Passive Safety Braking System: 4-wheel anti-lock brakes (ABS) Lights: Center high mounted stop light Ignition Security: Ignition disable Airbags: Dual airbags
Comfort and Convenience Features Air Conditioning: Dual zone front automatic air conditioning Radio: AM/FM/Satellite-capable Radio: In-dash mounted single CD player Door Locks: Power with 2 stage unlock door locks Instrumentation: Trip odometer Warning Indicators: Engine temperature Warning Indicators: Battery warning Warning Indicators: Low oil level warning Warning Indicators: Low coolant warning Warning Indicators: Door ajar warning Warning Indicators: Brake fluid warning Steering Wheel: Tilt steering Steering Wheel: Telescoping steering Windows: Light tinted windows Console Insert: Genuine wood
Posted: Today |
Superbot
Posted: Today |
Superbot
| All Forums > 2007 BMW M6 Cabriolet > Specs. > Post Reply |
