All Forums > 2007 Lamborghini Gallardo Nera > More Spec. on the 2007 Lamborghini Gallardo Nera > Post Reply
Post #1 Tue, Dec 12, 11:21 AM
jumpman23
Senior Member - 370
Year 2007
Make Lamborghini
Model Gallardo Nera
Engine Location Mid
Drive Type 4WD
Body Material Aluminium body and aluminium space frame
Weight 1470 kg | 3241.4 lbs
Combined MPG 14.00
Introduced At 2006 Paris Mondial De L'Automobile
Performance
0-60 mph 4.1 seconds.
1/4 Mile 12.2 seconds
Top Speed 309 km/h | 192 mph
Engine
Engine Configuration V
90-degree
Cylinders 10
Aspiration/Induction Normal
Displacement 4961.00 cc | 302.7 cu in. | 5 L.
Valves 40 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 500.00 BHP (368 KW) @ 7800.00 RPM
Torque 510.00 NM (376 Ft-Lbs) @ 4500.00 RPM
HP to Weight Ratio 6.5 LB / HP
HP / Liter 100.0 BHP / Liter
Redline 8100
Bore 3.25 in | 82.6 mm.
Stroke 3.65 in | 92.7 mm.
Compression Ratio 11.0:1
Fuel Type Gasoline - Petrol
Fuel Feed Multi-point Sequential Fuel Injection
Block Aluminum
Head Aluminum
Vehicles with similar horsepower and weight
Gear Ratios
1st Gear 2.563:1
2nd Gear 1.850:1
3rd Gear 1.423:1
4th Gear 1.138:1
5th Gear 0.939:1
Standard Transmission
Gears 6
Transmission Manual
Final Drive 3.077:1
Dimensions
Seating Capacity 2
Doors 2
Produced 185
Exterior
Length 169.301 in | 4300.2 mm.
Width 74.801 in | 1899.9 mm.
Height 45.901 in | 1165.9 mm.
Wheelbase 100.801 in | 2560.3 mm.
Front Track 63.901 in | 1623.1 mm.
Rear Track 62.701 in | 1592.6 mm.
Vehicles with similar dimensions
Suspension
Suspension Anti-roll bar and double wishbones
Steering
Rack and Pinion with Variable Power Assist
Brakes
Front Brake Size 14.401 in | 365.8 mm.
Rear Brake Size 13.201 in | 335.3 mm.
Tires / Wheels
Tires Front : 235/35 ZR 19 Pirelli Pzero
Wheels Front : 19 x 8.5 in
Posted: Today
Superbot
Posted: Today
Superbot
