Post #1 Sat, May 5, 9:37 AM |
jumpman23
Senior Member - 370
The Murcielago LP640 Versace Edition is technically the same as the regular LP640, and it features an all-white exterior and a matching customized interior.
Powerful Engine
The engine of the new Murcielago LP640 has undergone outstanding and radical modification. The increased bore and longer stroke have boosted the displacement of the classic 60° V-engine from 6.2 liters to 6.5 liters. Thus the already extraordinary 580 bhp engine power has now been elevated to an impressive peak of 640 bhp at 8,000 rpm. The 12-cylinder engine reaches a maximum torque of 487 lb-ft at 6,000 rpm.
The new Murcielago LP640 features a modified sixratio gearbox as well as a tougher rear differential and new axle shafts. On request, the e-gear automatic gearbox is also available equipped with the new dedicated Thrust (acceleration programme) mode.
Frame and Chassis: Perfect Harmony
The body of the Murcielago LP640 with its characteristic scissor doors is created from the prized union of sheet steel and honeycombed carbon fiber, glued and riveted together.
Driving, handling and stability at high speed are enhanced by new springs and stabilizers, as well as by a redesigned electronically controlled damper. The "antidive" and "anti-squat" features on the axles, which efficiently prevent so-called "brake diving" and "squatting", have not been changed. The two springs on every rear wheel, the single spring on every front wheel and the damper are placed coaxially.
Drivetrain
Configuration:Mid Engine/AWD Engine:V12 Displacement:6496 cc Horsepower:640 bhp @ 8000 rpm Torque:487 lb-ft @ 6000 rpm Transmission:6-Speed Manual
Posted: Today |
Superbot
Posted: Today |
Superbot
| All Forums > 2006 Lamborghini Murciélago LP640 Versace Edition > Specs. > Post Reply |
