Post #1 Mon, Feb 12, 10:42 AM |
jumpman23
Senior Member - 370
2007 Beck LM 800 Year 2007 Make Beck Model LM 800 Engine Location Mid Drive Type Rear Wheel Limited slip differential Weight 900 kg | 1984.5 lbs
Performance 0-60 mph 3.0 seconds.
Engine Engine Configuration V Cylinders 8 Aspiration/Induction Turbocharged Displacement 4.20 L | 256.3 cu in. | 4200.8 cc. Horsepower 650.00 HP (478.4 KW) HP to Weight Ratio 3.1 LB / HP HP / Liter 154.8 BHP / Liter Fuel Type Gasoline - Petrol
Standard Transmission Gears 7 Transmission Manual Semi-sequential
Dimensions Seating Capacity 2 Doors 2 Exterior Length 3960.001 mm | 155.9 in. Width 2043.001 mm | 80.4 in. Height 951.001 mm | 37.4 in.
Post #2 Mon, Apr 2, 11:34 PM |
arclight
Supercar Messi - 2432
good job,where did you get the figures and any word on top speed and quarter mile.
Posted: Today |
Superbot
Posted: Today |
Superbot
| All Forums > 2007 Beck LM 800 > Specs. > Post Reply |
