Post #1 Mon, Jan 16, 9:05 AM |
thunderbunny
Supercar Messiah - 1270
How do you think it would fair against something like an audi r8 or courage c60.. or porsche rs spider, etc..? Hopefully this is a more interesting comparison than the "dauer vs olds" bit.
CMG: "Don't hate the player, hate the Earth."
Post #2 Mon, Jan 16, 10:42 AM |
ajzahn
Posts - 62414
the 962 LM still would be competive to the current LMP1/2 racers due to the limited aerodynamic packages of the modern ones. The 962 was banned due to its improved aero package.
Post #3 Tue, Jan 17, 7:51 AM |
thunderbunny
Banned for the aero package!? That bites. I'm sure there are alot of coinciding laptimes that would put things in perspective, but I know no sources on such. What kind of a gap are we talking about in terms of compared laptimes?
Post #4 Thu, Jan 19, 5:22 AM |
MT900S
Senior Member - 282
Group C had less restrictions than the modern LMP1 cars. Hell, the R8 had to have special restrictions so that it wouldn't run away from the competition (as much). I'm sure that with a few modern-day tweaks, a Group C car can take on an LMP1.
Post #5 Thu, Jan 19, 10:10 AM |
ajzahn
Posts - 62414
Group C cars still achieve much higher top speeds and cornering speeds than the LMPs
Post #6 Fri, Jan 20, 4:06 PM |
mpg
Racer X - 21282
Quote from ajzahn Group C cars still achieve much higher top speeds and cornering speeds than the LMPs
Are you sure about the cornering speeds?
Post #7 Fri, Jan 20, 10:37 PM |
ajzahn
Posts - 62414
3g, yes!
Post #8 Sat, Jan 21, 9:39 AM |
MT900S
Senior Member - 282
3G in what corner? A car will not pull the same amount of lateral G loads in each corner, you know...
Super GT cars are pulling almost that much in the "130R" corner at Suzuka and they are no where near the same level as sportscar prototype racers.
Edited by MT900S - Sat, Jan 21, 9:42 AM
Post #9 Mon, Jan 23, 8:49 PM |
thunderbunny
Quote from MT900S 3G in what corner? A car will not pull the same amount of lateral G loads in each corner, you know...
WOAH! 3Gs? No offense, but lets see a link.
Post #10 Thu, Jan 26, 5:36 AM |
MT900S
Senior Member - 282
Quote from thunderbunny WOAH! 3Gs? No offense, but lets see a link.
Here is an interview with Nismo driver Micheal Krumm...
http://www.speedarena.com/news/publish/features/printer_4663.shtml
...In one line he says "In the test sessions at Suzuka, we measured the lateral G force, and it was something like 3G."
Post #11 Wed, Feb 1, 7:13 PM |
thunderbunny
Dang... but that article did say that super gt times are rivaling that of formula 3000 cars. What would really be conclusive would be to get info on the skidpad of that new Porsche lmp or something else that we know is under testing that would disclose such info.
Post #12 Thu, Feb 2, 4:49 AM |
MT900S
Senior Member - 282
Quote from thunderbunny Dang... but that article did say that super gt times are rivaling that of formula 3000 cars. What would really be conclusive would be to get info on the skidpad of that new Porsche lmp or something else that we know is under testing that would disclose such info.
How would that be conclusive? Different cars will pull different lateral-G in different corners. A car can pull more lateral G in a small radius corner than another car, but also might pull less in larger radius corners. It all depends on how the car is set up.
Post #13 Sat, Feb 4, 7:15 PM |
thunderbunny
Quote from MT900S How would that be conclusive? Different cars will pull different lateral-G in different corners. A car can pull more lateral G in a small radius corner than another car, but also might pull less in larger radius corners. It all depends on how the car is set up.
Well, like I said earlier, there are probably coinciding laptimes... and maybe coinciding research.
Post #14 Sun, Feb 5, 7:35 AM |
mpg
Racer X - 21282
Quote from thunderbunny Well, like I said earlier, there are probably coinciding laptimes... and maybe coinciding research.
MidOhio hasn't been modified since the late 80s. The newer 962s that raced there in the early 90s were running lap times around 1:14. Current LMP2s are almost that fast, and the LMP1s are around 1:11.
http://racingsportscars.com/photo_alms.html
Post #15 Fri, Feb 10, 7:17 PM |
thunderbunny
YES! That's what I was looking for! Thank you MPG.
Post #16 Sun, Feb 12, 9:43 AM |
mpg
Racer X - 21282
You're welcome thunderbunny. Please note that the early 90s were the latter years for racing 962s, so those should be the fastest IMSA 962s. The ones on the other side of the pond may have been a little faster. Mosport is a track that's never been modified, so its lap times are good to look at if you're curious about older cars. If you're curious about how the 917/30 compares to newer cars, it's not even as fast as a 935.
Post #17 Wed, Jun 25, 9:59 PM |
Sam Cool
New User - 64
Thanks mpg for the link!
My Dream Garage: Noble M12 GTO-3R, TechArt GTstreetR, Radical SR8, Saleen S7TT, Dauer 962LM, McLaren F1 LM, Lotec Sirius, Leblanc Mirabeau, Ford GT, Chevorlet Corvette ZR1, Koenigsegg CCXR
"Think of how stupid the average person is, and realize half of them are stupider than that."--George Carlin (1937-2008) R.I.P the guru of edgy stand up & anti-socialist routines on stage.
Posted: Today |
Superbot
Posted: Today |
Superbot
| All Forums > 1994 Dauer 962 Le Mans > 962 vs. modern LMPs > Post Reply |
