Post #1 Fri, Aug 9, 11:17 PM |
BMW Freak
Member - 86
Post #2 Fri, Aug 9, 11:17 PM |
a b c
New Member - 24
I think its enough to get from 0-60 mph in 3.3 seconds
hehehe
with best wishes All
Post #3 Fri, Aug 9, 11:17 PM |
squarehead911
Member - 125
speed is no laughing matter. 670 is a really sickening number. That's really fast. I hope that you're not laughing at the car, because although I hate Lamborghini, I can admit it's fast
Post #4 Fri, Aug 9, 11:17 PM |
Fear The Lambos
New Member - 8
Turbos don't just give out huge HP numbers..some can be used for low/mid/high range boost to help in acceleration and topspeed. You have watched the Fast and the Furious too much if you believe that turbos give huge HP. They can be used in many different ways...personally i'd use them for paper weights.
Post #5 Fri, Aug 9, 11:17 PM |
blaze4eva
Supercar Guru - 898
hello. it probably runs a sequential twin turbo on each of the cylinders. they could just use a twin turbo for the same effect, but i'm assuming that would 1)make it hard for the plumbing 2)not produce the same linear torque/hp so really because it has two banks of cylinders this is just like a twin turbo on a car with an inline engine. its probably also set to a low boost level dolt.
Posted: Today |
Superbot
Posted: Today |
Superbot
| All Forums > 1998 Lamborghini Diablo Evolution GTR > 4 turbo's and 670hp?????? hahaha > Post Reply |
