Mercedes is set to release its next-generation E-class sedan by 2009, with sales to start soon after the cars debut at the Geneva Motor Show. Remaining similar in size to the current model, the new E-class will pick up styling cues from the CLS four-door coupe as well as a new angular front end with four square shaped headlights. Base models will be powered by a 184hp four-cylinder turbo engine, with the range topping out with a 544hp V8 model. New to the lineup will be a direct injection petrol V6 model, a 354hp diesel V8 version and the all-new hybrid model thats expected to arrive after 2010. The interior will hopefully continue Mercedes recent return to form in the quality department, and is expected to feature a mix of elements from the S and C-class models including a centrally mounted color screen as well as an in-dash unit between the speedo and tachometer. The central control module and steering wheel uses a similar design to the ones used in the new C-class, and the side mirrors will also pick up the same integrated indicators. A wagon variant will hit the market less than 12 months after the launch of the sedan and will feature a widened C-pillar and a chrome strip across its rear. A second E-Class variant is rumored to stretch 20cm longer than the standard E-Class and be manufactured in China. It will be aimed at emerging markets where the owner of the car only ever experiences it from the back seat. Source: Motor Authority
whilst it probably wont look quite like a massive C-Class, those awful headlights have been done since the very first pshops of the new E-Class
God damn you Astley <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/angry.gif"></A>
If the made the front headlight one piece instead of that little divider thingy, it would look so much better
Actually all of those pshops are hell-old. Sadly, after the disaster that is "CLC," I really can't say for sure what Mercedes will do with the E. The CLS is the last new Mercedes I still like.
