Re: Everyone: list your car, any of mods on it, and where you li
Discussion in '2001 Pontiac Firebird Raptor Concept' started by 70SuperBee, Aug 10, 2002.
  1. Everyone: list your car, any of mods on it, and where you live
    I'll start:
    '94 pontiac formula firehawk. I did a few other things to it on my free time. I now dyno 654 HP at the rear wheels.
    K&N filter
    vortech supercharger
    brodix heads
    9" rear
    383 stroke
    cold air induction
    borla exhaust
    LT4 intake
    aluminum driveshaft
    racing flywheel
    hurst shifter
    bosch spark plugs
    bosch spark plug wiring
    bosch brakes
    I also took out the backseats, replaced some heavy parts with aluminum and titanium parts, and took out anything that I felt didn't need to be in the car. I ended up about 200 lbs lighter. I still have stereo and heating. The t-tops provide cooling.
  2. and what kinda tranny are you using to hold that power?
    I've had my car for half a year
    This year so far
    Built up the tranny to a world class T5 / Center Force Clutch / Hurst
    KYB suspension and lowering springs
    Mac Cold air
    Mac 2 1/2" H-pipe
    Flowmasters
    Advanced the timming
    Chrome ponies and tire
    Saleen Kit this winter
    New Paint and tints and body work. Custom frame connectors
    New Sterio
    Runs High 13's of the stock motor right now.
    Next winter
    INCON Twin Turbo kit w/ intercooler
    302 block bored over (305 ci.)
    TRW low compression forged pistons approx. 8.7:1 ratio
    ARP bolts/studs
    Clevite bearings, Speed Pro Moly Rings
    DSS main cap girdle
    Edelbrock Performer aluminum heads
    Edelbrock Performer intake
    BBK 65 mm Throttle Body and EGR Spacer
    Motorsport F303 cam
    Crane Double Roller Timing Chain
    Fel Pro Loc-Wire gaskets
    Motorsport SFI Approved Harmonic Balancer
    Injectors (nondecided)
    and drive line to a 3.73
    Motorsport HD radiator
    02 sensor readouts etc
    all wheel disc brakes ( I love the taking the turns aswell as hitting the flats)
    Also going to have side Exhaust
  3. 1994 T/A
    Raven Exaust
    Thats it im to broke to mode it right now but sum march im droping either a new ls1 in it or an ls6 and a super charger with a new 6 speed tranny
    anyway im from Hanover, PA<!-- Signature -->
  4. I was never really into nitrous. I like to upgrade a car w/ out a surprize shot of power. I like whooping people w/ nitrous. I'm going to add a little more power to my car soon. I'm a better throttle body and a new aftercooler for the supercharger. est'd 15-20 HP more. Not much, but good enough for me.
    BADASSAMERICANCARS, I like your car. If I could give an LT1 654 HP without nitrous, think of what you can do w/ the LS1.
  5. Allright, Formula, I'm a sucker for a muscle car, and you'll allways be better than a rice burner in my book.
    My baby (my other cars you'll have to ask, but they ain't nothin' to brag about):
    1966 Ford Mustang Coupe
    351 Cleveland motor with a 4140 Forged Steel crank, TRW forged rods and Speed Pro hyperuetectic pistons (stroked to 392 cubic inches in all), all ARP studs, moly rings (special CAlMustang bearings)
    Victor Jr Heads, 2.11 Intake, 1.73 Exaust, tripple titanium Crane valve springs, port/polished, blueprinted, 1.7:1 rocker ratio; Comp aluminum roller rockers, Crower Cam (238 In/Ex, lift 0.556), Pete Jackson gearbox
    Torker Manifold, Holly double pumper 830 cfm Carb (allthough I like Edelbrock's better), Holley Blue pump (140 gph max, 8 psi), MSD 7AL race ignition, Accel 8mm wires, MSD Blaster 2 Coil, MSD Billet distributor
    2800 RPM Stall on a tricked C-4 tranny with an extra-low 1st gear (bought it that way), Ford 9" 3.73 Posi
    16" Torquethrust II Wheels, 255/50R16 by 235/45R16 BF Goodrich rubber, Pioneer 4100-series deck, 2 6.5" Pioneer tripple-voice coil speaker off head unit, 2 6x9" XPlod 180-watt speakers off 200 watt Jensen amp (not bridged), 2 10" R/F Subs (560 Watts) off Sony 600-watt Amp (bridged), SuperComp 5" tach w/ shiftlite set at 3 grand (I shift at 6800, but who needs a shift light?)
    Corvette exaust (vintage 1966 side runners, you'd like it), racing seats, 4-point harness
    Ran a best of 12.36 @ 111.8 MPH at Seattle International Speedway, dynoed at 438.6 HP and 486.4 ft/lbs at flexplate. I live in Tri-Cities, WA; go cruising down Clearwater any weekend, you'll see me and Rich and Chris. Come get some, suckers.
    You should see Rich's shit...
  6. Here is the answer to FORDBOY's question: I forgot to list my tranny. I have a six speed hurst w/ A titanium clutch.<!-- Signature -->
  7. Hurst tranny or shifter?
    I forgot my titanium valve seats and Manley titanium valves, I think. Oh, and the carpet is from Luke's carpet, cut it myself.
  8. I have a hurst tranny and shifter. Cost me an arm and a leg, but was worth it. <!-- Signature -->
  9. <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from fordboy</i>
    <b>
    This year so far
    Mac Cold air
    Mac 2 1/2" H-pipe
    Flowmasters
    New Sterio
    Next winter
    ARP bolts/studs
    DSS main cap girdle
    Motorsport F303 cam
    </b></blockquote><center><hr width="90%"></center><!-- END QUOTE -->You run 13's? Impressive. Thats real good for that year stang.<!-- Signature -->
  10. CAR:
    2000 CAMARO SS (HUGGER ORANGE)
    MODS:
    K&N AIR FILTER, MASS AIRFLOW SENSOR, PAXTON SUPER CHARGER, BORLA EXHAUST, COMP CAMS CRANK AND CAM SHAFT AND BEARINGS, HURST SHORT SHIFTER, 15LB INJECTORS, TWIN PLATE CENTER FORCE CLUTCH, 3.73 AXLE GEAR, TRACTION BARS, CARBON DRIVE SHAFT, UPGRADED TRANNY, BAER BRAKES, COLD AIR INTAKE, BORLA HEADERS AND GASKETS, FORGED ALUMINUM DOME PISTONS: COMP CAMS VALVE SPRINGS, HYPERTECH UPGRADED CPU, AND LS6 INTAKE, 71MM THROTTLE BODY.
    REAR WHEEL HORSEPOWER: 589.6
    ENGINE NOT YET DYNO'D. MY ESTIMATE IS 615-635 HP
    RUNS CONSTANT 10.6.
    FUTURE MODS ARE: NOS FOGGER SYSTEM 15 LB TANKS 225
    SHOT.
    PS I LIVE IN CANADA ONTARIO.
    ALSO MORE FUTURE MODS TOO MANY TO LIST.
    AND 94 FORMULA AT THE STAGE WHERE MY SS IS IN YOUR FORMULA CAN SMOKE MINE!
  11. Import's aren't worthy.
    (Wish I had a Hurst transmission... damn).
  12. true though but the only import i lost to and had me by like 220 hp was an rx7! but this summer i'm after him.
  13. THANKS BRO BUT ITS NICE TO HAVE A SLEEPER SO THATS WHY I GOT STOCK RIMS ALSO ON THE OUT SIDE IT LOOKS STOCK WHEN I GET THE NOS THE BOTTLE WILL BE IN THE TRUNK CAUSE IT HAS THIS MOVING FLAP THING WHERE THE T-BARS GO SO IT WILL BE COVERED SO I SEEN A CAMARO ON NOS ONLY SMOKE A SUPRA WITH ABOUT $6500 IN MODS SO I'LL GO UP AGAINST ALL THOSE SUPRA'S RX7'S. BUT I CAN'T WAIT TILL MARCH TO UNLEASH MY BABY!
    PS: IF IT HITS ME I'LL SELL MY SS THIS SUMMER I'LL PROBABLY SELL ALL MY OTHER CARS TOO! (INTEGRA TYPE R, 93 MUSTANG LX 5.0)
    BUT KEEP MY WINTER CAR A 1989 CIVIC HATCHBACK AND BUY A
    1997 CAMARO SS SLP LT4 AND DO A $15.000 DOWN PAYMENT ON A 99' WS6 TRANS AM OR FIREHAWK.
  14. OH YEAH I ALMOST FORGOT THESE ARE SOME LT4 CAMARO'S ID LIKE TO CHECK OUT:
    PS: I WANT TO CHECK OUT A 1997 SLP LT4 CAMARO SS 30TH ANNIVERSARY OR A 1999 30TH ANNIVERSARY TRANS AM.
    WOW WHAT BEASTS.
  15. #15 70SuperBee, Aug 10, 2002
  16. One of my most beloved cars is my '78 malibu. Has a 454 w/ 938 HP dyno'd at rear wheels. I have titanium forged pistons, hydraulic camshaft, and many other things (too many to list). My most valuable upgrade is a supercharger. I built the whole engine from a bare block.<!-- Signature -->
  17. where do you bring that car bro to race?
    that car is a #$%#ing beast dude i'm gonna keep my ss #$%# nos and
    i'll make my ss one #$%#ing badass street machine not that its already
    but bro you gave me a good idea #$%# nos bring out the beast within
    thanks alot 94FORMULA <IMG SRC="http://www.supercars.net/servlets/cMsg/html/emoticons/smile.gif">
    PS. thanks for the sites<!-- Signature -->
  18. oh yeah do you think i can put an LT4 in my ss? 94 Formula cause you know hell of alot more than me. post a reply bro and tell me if i should or keep the LS1.<IMG SRC="http://www.supercars.net/servlets/cMsg/html/emoticons/smile.gif"><!-- Signature -->
  19. #19 70SuperBee, Aug 10, 2002
    <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from BAD ASS AMERICAN CARS</i>
    <b>oh yeah do you think i can put an LT4 in my ss? 94 Formula cause you know hell of alot more than me. post a reply bro and tell me if i should or keep the LS1.<IMG SRC="http://www.supercars.net/servlets/cMsg/html/emoticons/smile.gif"></b></blockquote><center><hr width="90%"></center><!-- END QUOTE -->LT4 is a badass engine, but the LS1 can put out more power when upgraded. An lt4 can't get nearly as much power as an LS1 is capable of when supertuning. The only reason I like the LT motor is because it has a higher torqe ratio when upgraded. I suggest you should just stick w/ the LS1 engine. Go on http://www.slponline.com/ and look for the 382 displacement upgrade for LS1. It costs $10,500, but is worth it. It will dramatically increase your overall power and give your car a higher torqe ratio. You can give your car over 1,000 HP when you upgrade the engine w/ superchargers and sh*t after increasing the displacement like that.
    In my opinion, I think you should stick w/ the LS1.
    I like your camaro. LS1 kicks ass.
  20. By the way, did you see my corvette yet?
    I sold my blazer and my WS6. Then I put a downpayment on a '97 LS1 vette.
    I will NEVER get rid of my firehawk. It took a very long time to get it tuned the way it is.
    I'm not going to put too many things on my vette, instead, I'm going to keep working on my malibu and my firehwak until they are perfect.
    I have my vette to cool down after racing in my firehawk.
    Yeah, keep the LS1, it took me a displacement increase to get most of my power. You still have a 350 displacement and have almost as much power as I do. That's impressive.
  21. By the way, how do you put smilies after a commment?
    I'm not interested, I just wanted to know how, because I don't see how.<!-- Signature -->
  22. #22 70SuperBee, Aug 10, 2002
  23. My car is a '99 firebird formula WS6.
    It has:
    Cold air induction
    ram air hood
    strange 9" rear
    hurst 6-speed trans
    hurst shifter
    foreged titanium pistons
    382 displacement increase
    raven exhaust
    titanium u-joints
    heavy duty aluminum driveshaft
    200 HP NOS BLAST
    12-point rollcage
    billet wheels
    holley camshaft
    My buddy, 94FORMULA helped me upgrade my stock LS1 into a 9-second superbeast.
    I get 867 HP at the rear wheels.
  24. hey 94 formula that is one BADASS vette black wow its sweet man i looooove it good job bro! i'll check out slponlinefor the parts thanks alot! you put it by typing : )<!-- Signature -->
  25. hey FIREHAWK your car sounds like a real beast bro i like it alot my ss will put out similar power unless it hits me to go all out to 1000hp+ on it i like your car and yours too 94 FORMULA its nice to see people that like 8 cylinder power. finnaly some people that understands my needs thanks bro's<!-- Signature -->
