1987 Ferrari F40 Prototipo
Discussion in 'Car Classifieds' started by basman007, May 11, 2007.
  1. #1 basman007, May 11, 2007
    Ferrari F40 One Of The Eight Known Prototypes And Very Low Mileage
    RM Auctions - Ferrari Leggenda e Passione 20th May 2007
    colour Red
    drive LHD
    type Coupe
    year 1987
    Chassis No. 74049
    Price estimate: 340.000 - 408.000 GBP
    VAT No
    Sale dates:
    May 20, 2007
    Preview dates:
    May 18 - 20, 2007
    Ferrari S.p.A.
    Circuito di Fiorano
    41042 Fiorano, Maranello, Italia
    An exclusive auction at the Ferrari Factory in Maranello, where the legend was born, dedicated exclusively to the most superb road going and racing Ferraris, as well as many virtually irreplaceable lots of Ferrari memorabilia.
    The first F40 prototypes were not really F40s at all, but 288 GTO Evoluziones. Five of these development exercises were built wearing bodies that had a mixture of GTO and F40 styling cues. The chassis and suspension parts developed for the 288 GTO Evo were to find their way under the upcoming model, but the first true F40 was chassis number 73015. It was assembled as a show car and greeted the public on July 21, 1987 at a press conference in Maranello. An aging Enzo Ferrari gave a speech praising the new F40 while drawing reference to the days when street cars could also be raced on the track.
    And raced they were. A total of 19 brutish F40LM racing versions were made up by Michelotto and campaigned with reasonable results, and some street cars were brought up to race spec as well. Other race versions were the mildly-modified F40 GT and the more developed F40GT/E, which competed in various series.
    Approximately eight F40 prototypes (73015, 74045, 74047, 74049, 74327, 75034, 75052 and 76354) were built for testing everything from suspension to drivetrain development. After being shown at the 1987 Frankfurt Auto Show, 74047 was sent to Michelotto and made into an F40GT that ran successfully in the 1992 to 1994 Italian GT Championship. Prototype 74045 was later transformed into an F40LM (and then into a GT/E) and ran Le Mans in 1995 and 1996, while number 76354 was shown at the 1988 Geneva Auto Show.
    Each of the F40 Prototypes was utilized differently, with each one serving a distinct and special purpose. One F40 Prototype was used to test the suspension system. Another was used to fine-tune the noise levels, pollution gear and brakes (power brakes were tried and rejected). One early prototype was set up for promotional purposes to car shows and press conferences. An unknown prototype gave its life against the crash barrier to satisfy American regulations, and one was used as a training dummy to instruct production line workers.
    As development progressed, new prototypes were made up incorporating changes suggested by testing the earlier efforts. Track testing was done at Fiorano, Nardo, Imola and at the Alfa Romeo test track at Balocco, while street testing took place on thousands of miles of Italian roads.
    Each F40 prototype differed in detail from the others, but there are visual differences from the later production F40s. Prototype tail sections have five louvers on each side underneath the spoiler, while the street cars have only four. Door mirror placement varies from car to car; some early prototypes have no outside mirrors, others have mirrors mounted on the side window while the street car mirrors are pedestal-mounted to the door itself. The Plexiglas rear engine cover also varies, with some prototypes having more louvers than standard.
    The chassis on 74049, the Ferrari F40 Prototype presented here, appears to be the same as the ones used on the production line, that is, a steel tubular frame built by Ferrari supplier Vaccari reinforced with carbon fiber and Kevlar panels. However, the body panels are lighter than stock. The hood, doors and rear deck replicate the European production items (no bumper protection like on the U.S. version), but are thinner and lighter. The doors sport Lexan side windows with sliding vents, as did the first fifty or so of the production models before customer complaints caused Ferrari to switch to heavier glass roll-ups. There is no side impact protection in the doors and the belly pan is Kevlar, versus steel on U.S. models.
    Five rear side vents on each side are consistent with prototype form, and the Plexiglas rear engine cover has twenty small slots, as opposed to just eleven larger ones on the standard cars. The side mirrors are mounted to the Lexan windows. In back, the license plate area is flanked by twin red fog warning lights, which were only fitted to European models (and even then they were usually on the lower valence panel instead). There is no high brake warning light on the rear deck as on U.S.-spec models.
    The interior is mostly standard. The dashboard and instruments are standard Euro F40 and Sabelt racing five-point safety harnesses are fitted on both sides. The seats are upholstered in red, and air conditioning is included for added comfort.
    Underneath, things are subtly different. The suspension bushings are stiffer replacements similar to the F40 LM. Luongo reports the corner weights were within seven pounds side to side as delivered (convenient, as turning is difficult with no adjustable coil spring lands). 74049 is also fitted with the adjustable ride height option, which can be manually switched on to raise the car up for traversing bumps, or in automatic mode will progressively lower the car as speed increases. Normal ride height is 4.9", which drops to 4.1" at 75 mph, but can be raised to 5.9" at low speeds. This hydraulic system was installed on very few cars (particularly in the U.S.); however a number of cars had the system retrofitted. The brakes are standard calipers and rotors, which operate with aggressive racing pads.
    On the scales, 74049 weighed 2,800 pounds wet, a good 200 pounds less than the 2,976 pounds (dry) weight of a U.S.-spec F40 (the competition LM reportedly weighed 2,315 pounds dry). Ferrari had initially announced the street F40 would weigh in at 2,425 pounds, but this was rather optimistic.
    74049’s true singularity lies in its powerplant; the standard F40 engine is a Tipo F120A, while the higher output F40 LM used a Tipo F120B. Interestingly, the engine plate on 74049 states that it has a Tipo F120AB, which may be a cross between the two. Although most major components are the same as a standard F40, 74049 is believed to produce 478bhp (tested at 7,500 rpm without air passing through the intercoolers). The IHI turbos are different from stock, but not the same as the ones on an LM. The ECU is an enhanced one-off unit. Intercoolers are standard, but do not wear the BEHR lettering of the street units. As with European models, there is no catalytic converter and many of the brackets for the exhaust system are hand-fabricated. The air cleaners are also subtly different for no apparent reason. The fuel cell housing is made from carbon fiber.
    The gearbox looks like a standard F40, and has a magnesium case like a 288 GTO. It is fitted with a three plate (vs. two on the standard F40) AP racing clutch with a special throw-out bearing. Another interesting detail was the number of parts on the car sporting hand-lettered part numbers that could be changed as the project developed.
    After its testing days were over, 74049 was retired. Reportedly, it spent time in the Ferrari museum before ownership was transferred by Luca di Montezemolo to a member of the Italian Royal Family. It subsequently passed through two additional owners since 1995 and is now being offered on behalf of its private North American based owner.
    Overall, its condition is as one would expect having been regularly maintained by certified Ferrari specialists for the last 12 years. It remains in exemplary cosmetic condition and shows only limited wear from use. The paintwork, engine and bay, underbody and interior are all equally clean and tidy and the F40 is ready to be driven without pause.
    The Prototype F40, chassis no. 74049 is an amazing cross between the production F40 and the competition-only F40 LM. And unlike the LM, it is at least plausibly streetable, as the current owner has driven the car to and from events. However, with only 800 original kilometers, he has curtailed much more street or track work for the time being. More than anything, it gives us a fascinating look into the life of a Ferrari prototype, where things are seldom as they seem.
    http://classicdriver.com/uk/find/4100_results.asp?bsubmit=true&lmodelflag=12270&lmanufacturer=10042&whatbutton.x=0&page=0&lCarID=1750750
    http://www.rmauctions.com/Carlist.cfm?SaleCode=FF07&Page=1&Category=Cars&SortBy=RO&Search=
  2. things a mile off the ground
  3. HAha, looks like a kitcar from that angle.
  4. �d buy if I can
  5. I thought it had +/- 600 hp ?
  6. If I saw that standing on some street, I'd assume it was a replica and hate it so much.
  7. Why do you think it looks like a replica ? Its just sitting a bit higher than a reg F40..The rest is the same.
  8. quite a nice car
  9. *lights in the front air dam, side windows.
