4WD ?????? What the!!!!!!
Discussion in '1952 Porsche-Glöckler 356 Roadster' started by Lightnings are rear wheel drive, Aug 9, 2002.
  1. Lightnings are RWD! Lets fix it with the correct information boys.
  2. Re: 4WD ?????? What the!!!!!!
    hu
  3. Re: 4WD ?????? What the!!!!!!
    Hu what!
    Look above it says 4wd in the stats. It is not 4 wheel drive it is rear wheel drive. Get it now?
  4. Re: 4WD ?????? What the!!!!!!
    <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from Roadkil68</i>
    <b><!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from Roadkil68</i>
    <b><!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from Lightnings are rear wheel drive</i>
    <b>Lightnings are RWD! Lets fix it with the correct information boys.</b></blockquote><center><hr width="90%"></center><!-- END QUOTE -->Wer did u get these crazy results??????????????????</b></blockquote><center><hr width="90%"></center><!-- END QUOTE -->K so to prove this wer did u get those results! What site is it What magazine is it!!!!!!!</b></blockquote><center><hr width="90%"></center><!-- END QUOTE -->
    speak english. it is rwd, thats just common knowledge.<!-- Signature -->
  5. Re: 4WD ?????? What the!!!!!!
    Front Wheels F 45.7 x 48.3 cm / 18.0 x 19.0 in
    Rear Wheels R 45.7 x 48.3 cm / 18.0 x 19.0 in
    Front Tires F 295/45ZR-18
    Rear Tires R 295/45ZR-18
    please tell me something is wrong....
    18 x 19 wheels<!-- Signature -->
  6. Re: 4WD ?????? What the!!!!!!
    it is RWD, the chevy's SS truck is 4WD
  7. Re: 4WD ?????? What the!!!!!!
    Uhhh It Says Here That It Is 4WD...Just Check Yourseleves
  8. Re: 4WD ?????? What the!!!!!!
    Look
    Position Not Available Drive Wheels Front Engine / 4WD
    Configuration Supercharged V8 Curb Weight 2120 kg / 4674 lbs
    Valvetrain Not Available Length 5283 mm / 207.9 in
    Displacement 5410 cc / 330.1 cu in Width 2009 mm / 79.1 in
    Power 268.5 kw / 360.0 bhp @ 4750 rpm Height 1801 mm / 70.9 in
    Torque 596.6 nm / 440.0 ft lbs @ 3000 rpm Wheelbase 3043 mm / 119.8 in
    Bore 90.0 mm / 3.54 in Front Track F 1661 mm / 65.4 in
    Stroke 105.6 mm / 4.16 in Rear Track R 1661 mm / 65.4 in
    Redline 5250 rpm Steering Power Assisted Recirculating Ball
    HP / Liter 66.54 bhp per litre Body / Frame Unti Steel
    HP / Curb Weight Front Brakes Vented Discs w/ABS
    Gear Type 4-Speed Auto Front Brake Size F 307 mm / 12.1 in
    1st Gear Ratio 2.71:1 Rear Brakes Vented Discs w/ABS
    2nd Gear Ratio 1.53:1 Rear Brake Size R 333 mm / 13.1 in
    3rd Gear Ratio 1.00:1 Front Wheels F 45.7 x 48.3 cm / 18.0 x 19.0 in
    4th Gear Ratio 0.71:1 Rear Wheels R 45.7 x 48.3 cm / 18.0 x 19.0 in
    5th Gear Ratio Not Available Front Tires F 295/45ZR-18
    6th Gear Ratio Not Available Rear Tires R 295/45ZR-18
    7th Gear Ratio Not Available Front Suspension Not Available
    Final Drive Ratio 3.55:1 Rear Suspension Not Available
  9. #9 jaguarkid02, Nov 23, 2002
    yeah we all saw that but what he's saying is that supercars.net is wrong. go to www.svt.ford.com and look around
  10. Re: 4WD ?????? What the!!!!!!
    this is what Truck Trend says from the March/April issue 2001
    Drivetrain layout . . . . . . . .Front engine, rear drive
    Top speed, mph . . . . . . . . . . . . . . . . . . . .142
    Wheels . . . . . . . . . . . . . . . . . . . .18x9.5-inch
    lots of things are wrong. I'll stop by saying Torque is 440 and Horsepower is 380.
  11. Re: 4WD ?????? What the!!!!!!
    its rwd. and the 99 and 200 only had 360 hp. my 02 has 380.
  12. Re: 4WD ?????? What the!!!!!!
    what tha f@cuk
  13. Re: 4WD ?????? What the!!!!!!
    HA, you're a #$%#ing idiot. Haven't you learned yet that SC.net posts sh!t wrong all the time. They're as dumb as you. Thats why you probably think the Skyline is the best car in the world too. F^ckin dumb sh!t.
  14. Re: 4WD ?????? What the!!!!!!
    everyone knows lightnings are RWD you dumbass
  15. Re: 4WD ?????? What the!!!!!!
    Hey buddy, im a domestic and ford fan first and foremost, but the skyline comes damn close to the best car in the world. they can put out over 1000 horses and are 4wd (actually I think AWD but im not totally sure) and thats with a straight six. that is damn impressive and the skyline handles like a dream too. not much can compare with the skyline, maybe the vr-4 and supra, but not much else.
  16. Re: 4WD ?????? What the!!!!!!
    Very, VERY few cars are 4WD especially performance cars so you can be garanteed that it is AWD.
  17. Re: 4WD ?????? What the!!!!!!
    its only teporaraly awd mostly it sends 100% of the torque to the rear.its only awd for the whole shot or to stabalize the car by sending and turning all the wheels indepedintly
  18. Re: 4WD ?????? What the!!!!!!
    ur perdy dumb your self, the skyline comes within inches of the best car on the planet.
  19. Re: 4WD ?????? What the!!!!!!
    Kinda off topic but since the cars were brought up, and for people that might not have known: the VR-4 and Stealth RT/TT are FULL TIME AWD.
  20. Re: 4WD ?????? What the!!!!!!
    4WD is defined as having a low range of gears for primarily trucks. AWD has a higher range for cars and trucks that can't do $H!T. <A BORDER="0" HREF="http://www.supercars.net/emoticons.html"><IMG BORDER="0" SRC="http://speed.supercars.net/cboardhtml/emoticons/wink.gif"></A>
  21. Re: 4WD ?????? What the!!!!!!
    yup i was about to make a comment about the 4wd mistake its rwd!!!!
  22. Re: 4WD ?????? What the!!!!!!
    its rear wheel drive
  23. Re: 4WD ?????? What the!!!!!!
    its rwd
