computer/networking people
Discussion in 'General Chat' started by Aych Es Vee, Feb 1, 2017.
  1. I have internetz question.
    So I've just finished building a house in my backyard, and that house shares a lot of services, such as water and electricity.
    We are good friends with the tenants and want to share our internet service with them, but i want to have our own networks/wifi. How do I do that?
    I'm guessing I cant have my router simply have a direct connection to theirs, and each have our own networks, but same internet service? Or can I?
  2. Some routers allow you to create a guest network, essentially providing two different WI-FI accounts.
    Many routers are dual band, which means you can set up two different WI-FI networks (with two different frequencies).
    Or get another router.
  3. yah, they have their own router. Do I simply connect the 2 routers LAN to LAN?
  4. You can connect one router to another. You'll have to fiddle with some settings to allow the secondary router to give out IP addresses.
    I think this might be a good guide.
    http://www.wikihow.com/Connect-Two-Routers
  5. And you must make sure both routers don't share same span of IP-adddresses. ex. if first router share 192.168.0.xxx, make sure the second one share 192.168.1.xxx
  6. #6 xDRAN0x, Feb 1, 2017
    Some "high-end" home routers will enable you to do this through VLAN (logically separating the networks) or with a guest networks (this sucks usually unless its an enterprise solution)
    If I were you, I'd gear up and use wifi for this
    https://www.ubnt.com/
  7. No. Can't be done. Tell them to leach off someone else. Bastards. Tell em to buy a bigger data package an to hotpot of their phone. Jerks......
  8. subnet it
    edit: oh keep in mind it's tricky with the last digit, it doubles mannn
  9. It really is worthy to invest to have a good setup, especially how "critical" Internet connectivity has become nowadays
  10. Give them this and tell them to piss off right proper:
    [​IMG]
