Design your own ultra wild road car
Discussion in 'Car Comparisons' started by F50Fanatic, Apr 17, 2006.
  1. OK! Eureka! ...(isn't that how you spell it?)
    There it is... but you can scratch that thing about how it would look like a jgtc NSX. I've done other sketches that were cleaner... and the headlights are quite off.. but this is the best representation of what I'm thinking it should look like.
  2. I like it a lot. Do you have a pic of the back?
  3. a FXX with 8c competizione chassis
  4. I just did this, but the idea is still cooking. I wanted it to look as much like the back of an f1 car and the back of a Porsche 550 as possible.
  5. OMG lol how about a fiberglass lump of shit with a "1000+" hp TT'd V8, and call it "da fastust cur in da wurld".
  6. very original, I like it
  7. The back looks like it would produce lift.
  8. very nice, i like the big ass tires.
    venturi tunnls need a bit of work though...
  9. Yes... yes they do.. You'd think I'd see that as I was drawing it.
  10. Mid-Engine, Rear Drive 2 seater coupe
    3.2 liter, 6 cylinder, twin turbo
    8000 rpm redline
    6 speed manual
    COD = .28 or lower
    muscular styling, particularly on the back end (the only part that people are gonna see)
    color= midnight blue pearlescent
    lightweight flywheel
    heavy feel to steering and gearbox
    lateral g = 1.00 or higher
    0-60 = 5 seconds or better
    0-100 = 11 seconds or better
    1/4 mile time = i don't care, because it doesn't matter
    top gear, 50-80mph time = less than 8 seconds
    firm ride
    selective traction control
    ABS
    reasonable cargo space
  11. I'd like a Hartge tuned BMW. Either the 3-series compact or the 1-series. Sleeeeeper. I'd take off the custom bumpers though, just to make it even more sleeper <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/smile.gif"></A>
  12. i want a noble M400, black with black rms, and with Zonda engine. Or a carrera GT.
    happy days...
  13. u think that would fit? maybe the CGT engine could be squeezed in with some work but the zonda's 7.3L v12 is huge... AMG is not one to make light and compact anything...
  14. ENGINE: 6.8L DOHC TT 32V V8,VVL+VVT.
    horsepower:[email protected]
    torque:110lb-ft
    revline:9200rpm
    TRANSMISSION:7-speed DCT
    BODY: Carbon Fiber Monocoque
    drag coefficient: ~.330
    weight:3000lb
    DRIVETRAIN:4WD
    SUSPENSION:pullrod accuated Double wishbone suspension with magnetorheolic shocks and adjustable ride height.
    anti-roll bars:Hydraulic
    Tires:pirelli P zero corsa
    Wheels: 19" carbon fiber
    0-60<A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A>2.5 seconds
    Top Speed<A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A>275
    Max Lateral G<A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A>1.30
  15. ENGINE: 6.8L DOHC TT 32V V8,VVL+VVT.
    torque:110lb-ft
    revline:9200rpm
    weight:3000lb
    DRIVETRAIN:4WD
  16. <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A><A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/confused.gif"></A>
  17. 70 Hemi Cuda set up for FAST racing(Factory Appearing Stock Tire)
    engine looks and sounds stock down to exhaust note, air cleaner, and plug wires
    internally lightened block bored to max and converted to oversize diameter roller cam
    ported heads with larger intake and smaller exhaust valves relocated more vertically
    factory intake reworked with popcicle sticks
    ported exhaust manifolds with stepped sizing inside
    extrude honed fuel lines with blueprinted pump
    acid dipped body
    Shaker hood
    A-833 4 speed with lightened case and lightweight micropolished guts
    factory appearing interior that is actually hollow except driver seat
    tiny factory tires with sidewalls thinned from the inside for wrinkle wall and then soaked in traction aid
    mid 9 second 1/4 mile times looking like it just rolled off the assembly line
  18. probably just a Quattroporte GTS
