And Information technology 2001 Unit two sac two 1. Describe the function of the component in an information system. The function of the component information system is to provide security for the internet. It uses fingerprints to provide security to access the internet. The component may also be used to save passwords and login names for the internet, which makes their access to internet sites much easier for the user because he or she do not need to remember the passwords or any login names. This component is very good because it provides total security for a very low price. The component may also be used to access a computer, thus itÂs very versatile for many uses. The component may also be used to access saved data. This may be useful for larger companies and organizations, because no competitor can hack into your computer and files. 2. The waters the purpose of the biometric device? The as I just explained before in the passage above the purpose of the biometric device is To provide safe log on to the internet and internet sites using the indication of the fingerprint. 3. Where does the biometric device fit into the information system? The devices used to process the input which In other words means that it processes the input of the fingerprints and provides access the users which are allowed to use the computer and view the saved files. I will show you in the following picture where the biometric device fits. Throughput Input Process output Data internal feedback External feedback As you can see in the picture the device is used to process the input, by that I mean that the user scans his fingerprints with the hardware and the software that is used with the hardware will then look up the user in its database and log on the user if he is allowed to log on the computer of the internet. 4. Describe the Technical capabilities of the component The Technical capabilities or product Specifications are shown below. The technical capabilities of this product are very impressive for its small price of $129.52 American dollars, and you also get many different software to accompany the device such as, Fingerprint enrolment& system setup, Secure Logon, Secure Screen Saver, Secure session, and the Secure site tutorial. The products hardware specifications also are very impressive and I will state the all later on. 5. Detail the technological capabilities of the biometric device; such as memory size, storage capabilities, operating speed, data transmission rates, networking capabilities, visual resolution, etc. Touch Surface- TactileSense  Ruggedized patented polymer  0.075mm thickness Size- 2.3W x 2.1H x 4.6D inches (57.7 x 54.1 x 116.5 mm) Fingerprint Imaging Area- 0.76" x 0.56" (active) Imaging Resolution - 403 dpi Image capture time- Interface to Host - Standard USB interface USB Cable Length - 6 feet (1.83 meters) USB Cable Direction - Either direction based on user preference and finger placement LED Functions- ON - USB 2500 is powered on and operating correctly OFF - USB 2500 is powered off or not operating correctly BLINKING - USB 2500 is operating in fingerprint detect (image capture) mode Operating conditions - 0° C to 50° C, maximum 95% RH at 40° C (non condensing) Storage conditions - -20° to 65°C, maximum 95% RH at 40° C (non condensing) Mechanical and Environmental Tests - Meets USB 1.1 specifications Touch Surface Life - 1 million+ touches Certifications and approvals - FCC Part 15, Class B; Canadian ICES-003 Class B DOC; European CE Mark; TUV; CISPR; VCCI; UL ESD - Conforms to IEC 801-2 and CE LEVEL 3 (8kV) Software  Driver / Operating System / Application Software Compatibility Operating Systems- Windows 98/98SE/Me/NT 4.0 (SP4 and greater)/2000 Client Operating Systems. NT Server (sold separately) Compatibility PCS- Most major PC manufacturers with at least one (1) available USB port, including: Acer, Compaq, Dell, Fujitsu, Gateway, HP, IBM, Micron, NEC, Sharp, Sony, TI and Toshiba. Power management - Supports ACPI and APM power management specifications Fingerprint Matching Algorithm - Ethentica Proprietary Biometric Standards Compatibility- BAPI compliant - Microsoft core biometrics standard Fingerprint Template Compatibility - BAPI compliant Fingerprint Matching Speed - Fingerprint Angular Variability- +/- 45 degrees Fingerprint Template Data Size - As you can see above, the device is very versatile in its appeal and also in its specifications. The device can save as many pictures and profiles as the computer hard disk capacity allows it to store. Because the device only stores specific points of the finger picture and not the whole thing the pictures only take up a minimum of the storage space of the computer, which is about 300 bytes. The speed of the device also is very impressive, because it only takes .9 of a second to scan and identify your profile with a Pentium 133 processor.
