i almost have the same engine in my 89 mazda turbo
Discussion in '1992 Mazda 323 Familia GT-R' started by F50 chino, Aug 9, 2002.
  1. it is pretty fast
  2. Re: i almost have the same engine in my 89 mazda turbo
    What do you meen almost
  3. Re: i almost have the same engine in my 89 mazda turbo
    its probably the B6T<!-- Signature -->
  4. Re: i almost have the same engine in my 89 mazda turbo
    Almost? Don't you know what kind of engine you have?
  5. Re: i almost have the same engine in my 89 mazda turbo
    Can a B6T be mod to recive a turbo?
  6. Re: i almost have the same engine in my 89 mazda turbo
    well first of all b6t is the engine releasted in all mazda/laser cars from 85 to 90. the T on the end of b6 "b6t" stands for turbo. so if your talking about can a turbo be added on a b6t. chances are you already have one dumbass. now if you just had a b6 then yes you can make it into a b6t, you only need, a twincam head,"because most of the b6 engines are single cam. and the turbo manifold does not bolt up to the single cam engine. yes new engine mounts for the twincam head and a turbo manifold with turbo. and different pistons due to the 8valve piston design "groves" within the piston. now i useto own a ford laser tx3 4wd turbo. which is the exact to the 88 gtx 4wd. the only difference is its alot nicer. interior is better. and outside shape is better. anyway im off, and yes the b6t is a very powerfull engine and my one was running 20psi, chopping stupid v8's and all sorts of powerful cars, including famila gtx 88, only cause mine is chipped and fully worked, done by me.
