I think I have finally found VL calais front
Discussion in 'General Chat' started by Aych Es Vee, Jan 12, 2009.
  1. correct.
    front mount cooler + piping
    much larger radiator
    twin thermo fans
    trans cooler
    2.5 inch exhaust
    330mm rotor/twin piston front brakes, and VL V8 rear discs (276mm single pistons on the front before, and drum brakes on the rear)
    4.11 LSD differential gears
    28 spline axles
    Pedders shorter sport shocks and springs, new bushes, etc.
    a couple of other minor things.
    that stuff, coupled with me having to pay people to do the major stuff = around AU$10,000.
  2. Im not quite up to the technical knowledge of 4.11 LSD, whatever that means, sounds like ratios/gearing. Is that still a 1 way turbo diff?
  3. limited slip differential, with the same final gear ratio as an R33 GTST.
  4. #$%# this LSD shit, ima just weld mine up! <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/tongue.gif"></A>
    not really though
  5.
  6. Go on do it! im getting a s14 turbo lsd welding it up and also have my factory s15 helical diff come WOF (MOT) time
  7. I dun wanna be dragging the inside wheel when i drive around carparks and tighter corners and shit
  8. True that. It does make daily driving harder.
  9. #109 Veyronman, Jan 17, 2009
    one day i'll drift one of these:
    http://tinyurl.com/9vdbau
  10. #110 dnd, Jan 17, 2009
    Woah. It has the super long wheel base for awesome angle
  11. they crop up on ebay with surprising regularity. I'd so rock one as a DD if they weren't impossible to use in carparks
  12. THAT IS WHAT THEY ARE DESIGNED FOR YOU DOODLE
  13. ALSO SIK AYCH
  14. i know, but like... they're ALL OVER the place in mine. lol
  15. see if you can hook up a digital dash from a 90's early maxima brougham. its probably the best looking one out there IMO.
  16. OKAY
    Can you get me tickets to first ashes test? I'm staying in London though and test is in Cardiff. I want to go still. I dunno.
  17. eh, it's straight down the M4 then over the severn into Wales... about 3 hours driving provided it goes through smoothly. or train, but i duno how long that takes - probably faster, and it'll probably be full of Cricket fans getting dtunk
  18. Okay I go there.
  19. This thread didn't suck nearly as much as I thought it would.
  20. I ziptied the top of my thermo fans on .... HA
  21. They're #$%#ing called #$%#ing cable ties you #$%#s.
  22. THATS THE ONES.
    lol @ VL thread making it to 5 pages on sc.net.
  23. TEN THOUSAND DOLLARS
    JESUS CRHSIT
  24. ^
    yeah man, just the diff and brakes costs $1500 each.
  25. more like 13 with STOCK setup
