Imagine an S5000
Discussion in '2000 Honda S2000' started by biturbonite, Oct 12, 2003.
  1. Re: Imagine an S5000
    ???? I don't get it....
    do you mean an S2000 with a 5.0 engine?
  2. Re: Imagine an S5000
    yeah. And 500 horse power <A BORDER="0" HREF="http://www.supercars.net/emoticons.html"><IMG BORDER="0" SRC="http://speed.supercars.net/cboardhtml/emoticons/grin.gif"></A>
  3. Re: Imagine an S5000
    It would be very nice but I think you're dreaming.
  4. Re: Imagine an S5000
    well, if the bhp/l would remain the same (which, of course, would not), perhaps they could leech 625hp out of it.
    That would be cool, but I don't think it's going to happen.
  5. Re: Imagine an S5000
    Then you dont have a 9000RPM redline?
    The 2004 S2000's in North America are getting bumped to a 2.2 litre engine with the same horsepower, and about 10 more ft/lbs of torque.
    It also has an 8000RPM redline. Carbon gear synchros, and shorter gears and the car is actually a lot faster then the previous year cars, especially in daily driving conditions. Although with the little bit extra displacement the engine should wake up nicely with some modifications and higher horse numbers will be easier to achieve then they were in the past with this car.
    BTW the 2.2 litre engine version will still be called an S2000, not an S2200.
  6. Re: Imagine an S5000
    Yeah, but I think I'm still going to use the original K20A under the hood of my Civic for rally racing.
    Edit: F20C
  7. Re: Imagine an S5000
    btw - forgot to add, I think they should make both engines available for the car, the ones in the dealership should be sold with the 2.2 litre engine, while the 2.0 should be available as a cheaper pre-order from the dealership.
  8. Re: Imagine an S5000
    and they say that the new engine will have good power even a 3000rpm compare to 6000rpm for the old engine.
  9. Re: Imagine an S5000
    I agree.
  10. Re: Imagine an S5000
    under s5000 maybe you mean something like s2000 but with 5.0 l engine?! If it is that way, i think that you`re a dreamer!!! Honda are not going to make that big engine! They make little engines with big power, thats why their bikes are one of the best in the world.
  11. Re: Imagine an S5000
    The RX-8 has 240 hp from 1,300 cc. So, what if Mazda made a 5,000 cc rotary engine. It could have 925 hp. With turbo it would have 1,250 hp. That would kick A$$.
  12. Re: Imagine an S5000
    A 5.0 litre rotary engine would have serious reliability issues, and would also not be able to spin nearly as fast, and would not be able to put out anywhere near the same power.
  13. Re: Imagine an S5000
    How do u figure that just get 2 20b side by side with quad turbos. Unreliable probably but wat a drag car.
  14. Re: Imagine an S5000
    That wouldn't be one 5.0 litre then. It would have an accumulated total of 5.0 litres, but if you were to look at it that way, then you would also have to say that it has 6 cylinders instead of 3.
  15. Re: Imagine an S5000
    They make 5.0l rotaries. well, mazda doesn't, but I know that a local engine shop where I live will build any size rotary you wan't (within limits). They aren't as high quality as mazda's... in fact they are only good for about 10 races, but they still produce gobs of power. I don't really knwo the exact specs, but they have built 6 cylinder rotaries there before for sure, and I think they may have made some 8 cylinders...
  16. Re: Imagine an S5000
    Umm...8 cylinders? that's impossible in a rotary.
    Rotaries have 3 chambers in each Cylinder head, wherein one of the three phases of combustion is occuring at any time, therefore they technically have 3 cylinders in one rotary engine, with a second one added they have 6 cylinders, but it's technically two cylinder heads, and therefore two engines, 8 cylinders would be impossible, but 9 cylinders would be possible, although it would technically be 3 engines.
  17. Re: Imagine an S5000
    Now your just nit picking... when I say 8 cylinders I mean cylinder heads.
  18. Re: Imagine an S5000
    lol, i dunno much about cars....so i dunno....
  19. Re: Imagine an S5000
    Well, they don't really even have cylinders, just chambers, but on each side of the triangular shaped rotor is the rotary engine's equivalent of a cylinder, so they don't really even have any cylinder heads.
  20. Re: Imagine an S5000
    Well, 8 chambers then LOL... I like rotaries, but I don't know the terminology to well for em.
  21. Re: Imagine an S5000
    But again, that would be impossible, because based on the rotary's design, there need to be exactly 3 chambers within each casing. The rotor is triangular shaped within an oval shaped larger chamber, the rotor spins, maintaining exactly 3 openings at all times.
  22. Re: Imagine an S5000
    s5000 means an s2000 with an 5.0L engine??
    how can a 5L engine fit inside an s2000? <A BORDER="0" HREF="http://www.supercars.net/emoticons.html"><IMG BORDER="0" SRC="http://speed.supercars.net/cboardhtml/emoticons/confused.gif"></A>
  23. Re: Imagine an S5000
    A 5.0L engine could easily fit under the hood of the S2000.
    It would #$%# up the 50/50 weight distribution though.
  24. Re: Imagine an S5000
    your freaking nit picking again :p I mean it has 8 main chambers (with the three sub chambers in it... or whatever)
