2002 Mercedes-Benz : CLK-GTR ROADSTER SUPERCAR CLK-GTR ROADSTER 1 of 5 ever! http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1872902488
Re: Look at this benz on ebay starting at 1.5 million usa. There are only 2 CLK-GTR's in the U.S. In addition, only one is a Strassenversion or a "street version." It is registered in Florida.
Re: Look at this benz on ebay starting at 1.5 million usa. wow can you picture showing up at your high school reunion in that thing!
Re: Look at this benz on ebay starting at 1.5 million usa. Mercedes CLK-GTR Roadster Open 2 door sports car based on the coupe Carbon fibre monocoque with integrated steel roll cage front energy absorbing crash box carbon fibre bodywork and aerodynamic parts Motor Number of cylinder and formation 12 cylinders 60Â ÂV-motor 4 valves per cylinder Engine capacity Cm3 6898 Bore and stroke Mm 89.0 x 92.4 Rated horsepower kW (hp) 1 / min 450 (612) / 6800 Torque Nm at 1 / min 775 / 5250 Max. rpm 1/ min 7200 Compression ratio 10,5 Mixture preparation Micro processor controlled petrol injection with Hot film air-mass sensor (Bosch HMS 6) Transmission Clutch Four plate clutch Gear box 6-speed sequential shift mechanism 1.gear 3.235 2.gear 2.097 3.gear 1.560 4.gear 1.231 5.gear 1.020 6.gear 0.871 Reverse 2.172 Suspension Front axle Double wishbone independent suspension Coil spring, spring actuated push-rod Gas shock absorber, roll bar Rear axle Double wishbone independent suspension Coil spring, spring actuated push-rod Gas shock absorber, roll bar Brake system Hydraulic dual circuit brakes with four or six piston calipers, hydraulic servo, ventilated disc brake front and rear Steering Rack-and-pinion power steering Light aloe wheels Front 10.5J x 18 Rear 12.5J x 18 Tires Front 295/35 ZR18 Rear 345/35 ZR 18 Weight and measurements Wheel base Mm 2670 Track front Mm 1665 Track rear Mm 1594 Total length Mm 4855 Total height Mm 1100 Turning circle M 15 Weight Kg 1410 Gross weight Kg 1630 Front axle weight Kg 710 Back axle weight Kg 920 Power / weight ratio Kg / kw 3.13 Luggage compartment capacity Ltr. 153 Fuel tank capacity Ltr. 90 Performance Acceleration 0-100 km S 3.8 Acceleration 0-200 km S 9.9 0-1000m from standing start S 19.8 Maximum speed Km/h 320 Fuel consumption Town 31.8 l / 100km Highway 14.7 l / 100 km Euro mix 21.6 / 100 km Unleaded 98
Re: Look at this benz on ebay starting at 1.5 million usa. Standard Features Removable leather steering wheel with airbag Passenger airbag Audio-system with CD-changer Central locking system with remote control Anthracite leather interieur within terms of color matched applicaton ABS /ASR Seven piece luggage set Electrically adjustable and heated wing mirrors Mechanical height adjustment Heated windshield Heat insulating glass Air conditioning Hydraulic jacking system Fire distinguisher for engine compartment Immobilization system
