Mercedes SLR McLaren MSO Edition: Driven
Discussion in 'European Cars' started by Veyronman, Oct 16, 2013.
  1. #1 Veyronman, Oct 16, 2013
    http://www.pistonheads.com/news/default.asp?storyId=28647
    Surely there can be nothing better in this world than a sodding great V8 with a supercharger and 600-odd horsepower?
    There is.
    One with side exhausts. And 'improved breathing'.
    Whatever other criticisms - often misguided - have been thrown at the Mercedes SLR McLaren a lack of aural drama has never been among them. And yet, when McLaren Special Operations decided to revisit the SLR, 'more noise' was on the agenda alongside 'sort the steering', 'improve the ride' and 'make it look even more mental'.
    All have which been accomplished and we'll return to. But first the noise.
    The SLR's AMG-built engine (a dry-sumped evolution of the M113 5.5-litre used in the SL55 and many others) has always had a ferocity and percussive violence pretty much unique even in the long history of noisy V8s. But McLaren's MSO Edition demo car is in another league.
    Having arranged meeting with PHer and TVR Wedge owner Simon Marzell promising something that'll challenge him in the decibel stakes he responds by bringing a noise meter. And looks a little worried when I pull up in the SLR. He scores a commendable 106db. The SLR? 116. At the ECU-capped 4,000rpm it'll permit at a standstill.
    From inside the SLR it's all about the engine noise. Then I open the windows ... 'kin hell! That'll explain the open-mouthed looks of amazement, and sometimes terror, I've been getting. Under even a tickle of throttle each detonation in the engine sends a pulse of noise out of the side pipes. On the overrun it sucks back in with breathy, distant thumps that crump like artillery shells.
    It's quite obviously marvellous.
    But then we knew that about the SLR. What we also knew, or thought we did, was that despite the noise and monumental straight-line performance it was a flawed car to drive. Twitchy steering. Grabby brakes. A sense that it was never quite tied down. And a torque converter auto.
    With the SLR project concluded, examples of all the derivatives in storage and this car - the 14th pre-production prototype or PP14 as it's known - knocking about the guys at MSO decided to start, in their words, 'playing around' with a car they affectionately refer to as the old girl. With 75,500 development miles on the clock, many of those racked up at the 'ring during shakedown for the 722 chassis mods, a few prangs along the way and a hard-knock life this is probably one of the hardest working SLRs out there. But one the McLaren boys clearly feel a huge amount of affection for.
    As is the way of these things a few light mods turned into something a little more involved and before they knew it an outside (and undisclosed - we asked) partner was drafted in to find a suspension set-up more composed than the standard SLR's but more comfortable than the rock-hard 722's.
    MSO also looked at the famously twitchy steering. Fast of rack, heavy around the dead ahead but with a falling rate off-centre it combines with the odd rear-biased seating position to create an unsettling balance. By adding an additional universal joint into the steering gear McLaren was able to straighten the path of the linkage, reducing this alarming sense of the steering suddenly 'speeding up' as you applied lock and generally make it feel more linear and natural. Relatively speaking, given that the front wheels are seemingly in a different postcode from where you sit.
    It doesn't take long to realise that the SLR, thus equipped, is vastly improved and more approachable. There's still a sense that, in its stride, you're riding a lit firework and merely along for what is an undeniably thrilling ride. This is a raw and still engagingly uncouth muscle car with more than a hint of menace about its handling. But now tamed just enough to make you feel involved rather than merely an alarmed passenger.
    Proximity of bum to rear axle makes judging the revised spring and damping rates an easy task and though still hardly yielding there's now class and subtlety to the bump absorption and resistance to the kind of pitch, roll and corkscrewing motions that could make fast progress in a regular SLR so alarming. In detail McLaren says rear spring rates were raised and damping increased all round for bump and reduced in rebound.
    As such the SLR makes a lot more sense. Even that auto doesn't seem such a bad thing; five ratios are adequate with an engine of this reach and the faster of the three manual settings is no worse than the jerky, slow-witted automated manuals in contemporaries like the Lamborghini Murcielago.
    On their own the steering and chassis revisions are available for all SLRs for £13,480 (plus taxes), one enthusiastic German owner who's racked up 90,000 miles in regular use opting for just that while leaving the rest of the car standard.
    Bringing us neatly to the looks...
    Now, you wouldn't buy an SLR if you were shy and retiring. But clearly there are owners for which the standard looks are not quite mad enough. Some have gone for chrome wraps. Some have gone aftermarket. Those who've approached MSO will have met a 'never say never' attitude but one grounded in more than just aesthetics, as one who requested a new front end discovered. "We had to explain it would have unsettled the car," says our source, adding, "it's never a straight refusal though. We have a constructive approach."
    Hence a new 'aero' look designed with both the suitable visual impact and engineering rigour an officially supplied upgrade requires. New front and rear bumpers and revised side gills with McLaren 'ticks' are included, the whole package increasing downforce by around a fifth. It's still got a three-pointed star on the nose but this SLR is a whole lot more McLaren than before.
    You need to go all-in to qualify as a full 'edition' car, the work costing over £100,000 and taking three to four months to complete. MSO will cap production at 25 and has built 'nine or 10' so far, selling to customers around the world. A couple have only gone for the rear bumper, others have requested different fronts and not all the colours have been as subtle and menacing as PP14's.
    An old dog with a few new tricks, and lessons to younger upstarts in how to create a stir. It took a while, and a bit of fettling, but with MSO's help the SLR really has come of age.
    MERCEDES-BENZ SLR McLAREN SPECIAL OPERATIONS EDITION
    Engine: 5,439cc V8 supercharged
    Transmission: 5-speed auto, rear-wheel drive
    Power (hp): [email protected],500rpm
    Torque (lb ft): [email protected],250rpm
    0-62mph: 3.8sec
    Top speed: 209mph
    Weight: 1,768kg (EC)
    MPG: 14.8mpg (NEDC combined)
    CO2: N/A
    Price: c. £150,000 (standard used SLR, MSO Edition c. £110,000 additional)
    SLR Edition package details (as quoted by McLaren):
    50kg weight saving
    20 per cent increase in downforce
    Revised Styling
    Optimised airbrake calibration to take advantage of increased downforce
    Optimised underbody with larger carbon rear diffuser for more effective airflow
    Lightweight carbon side panels
    722 GT inspired wheel arch and topshell vents
    Handling Package with new suspension and steering upgrades
    Ceramic Coated Lightweight Sports Exhaust
    McLaren Edition Branding with unique chassis number
    Carbon Fibre wing mirrors
    Carbon Fibre Branded Sill Panels
    722 S Wheels
    722 Light Package
    Visual Carbon front Splitter
    Historic Orange Brake Callipers with McLaren Branding
    Seat Comfort Package with bespoke trim
    Interior re-trim with perforated Orange Leather detailing
  2. Much better than any Mansory shit. Largely because they have just kept the standard 722 wheels instead of throwing some D's on that #%[email protected]
  3. They mention side exhausts but the stock one has those too.
  4. presumably they have been changed to make them more free-flowing, and louder as a result
  5. never digged the slr, this is no exception.
    looks like a dick.
  6. I didn't even know they still made it
  7. they dont, this is a retrofit
  8.
  9.
  10. I've always liked it, though thought it was always a missed opportunity. Wished McLaren were given an AMG engine/allowed to spec a custome one, given a mandate to make a front-engined two seater and then left alone.
    I love the idea of this, but would have expected them to bring the weight down too. The new nose looks like absolute shit too.
    EDIT: love the photo inside the workshop with the 12C and F1 GTR
  11. They still make the SLR?
    I had to double check that this thread wasn't a bump from many years ago.
  12. Phenomenal effort to read precisely none of the thread.
  13. that's that nissan racecar, whatever it's called
  14. pretty much
  15. yeah the coupe deltathing is bad
  16. #18 Vision K2, Oct 24, 2013
