MORE INFO FROM LOTEC's HOMEPAGE:
Discussion in '2001 Lotec Sirius' started by 26y4u, Feb 3, 2007.
  1. #1 26y4u, Feb 3, 2007
    Technical specifications
    Chassis and body: Manufactured from the lightest and most modern materials applied in the aerospace and automobile industries, carbon fiber composites combined with tubular steel.
    The bodywork is produced from the optimum combination of carbon, Kevlar and glass fiber materials.
    Engine: Mercedes 600 V 12
    Position: Mid-engine
    System: V-12 engine, 48 valve, double Turbo
    Cylinder capacity: 5987 ccm
    Bore x stroke: 98,0 x 80,2
    Compression ratio: 8,5 : 1
    Valves 4 per cylinder
    Turbo charging: 2 special KKK Turbo charger K 27
    Intercooling: twin air - air intercooler
    Lubrication: drysumplubrication
    Cooling: water
    Performance / horse power (variable):
    0.85 bar boost: 1.000 h.p. at 6.300 r.p.m.
    1.20 bar boost 1.200 h.p. at 6.300 r.p.m.
    Performance / KW (variable):
    0.85 bar boost: 735 Kw at 6.300 r.p.m.
    1.20 bar boost: 882 Kw at 6.300 r.p.m.
    Max. Torque:
    0.85 bar boost: 811 lbf ft at 3400 r.p.m.
    1.20 bar boost: 974 lbf ft at 3400 r.p.m.
    Acceleration (km/h): 0 - 100 at 3.8 sec.
    0 - 200 at 7.8 sec.
    Top speed: V - Max up to 400 km/h (optional transmission)
    Tachometer: up 400 km/h
    Break system front: Brembo ventilated racing disk brakes with ABS
    Break system rear: Brembo ventilated racing disk brakes with ABS
    Gearbox and power transmission: 6 speed manual gearbox from CIMA,
    synchronized limited slip differential,
    transmission oil cooler
    Motor-Management: LENZ Turbo-Tronic, www.lenz.de
    Suspension: Independent front and rear suspension with unequal length upper and lower A-arms, coil springs, tube shocks, anti-roll, bars and power steering. Racing power brake system including ABS
    Tires and Rims: 3-piece Works-Rim with
    9,5 x 19" 255/40 ZR 19" front
    13 x 19" 345/30 ZR 19" rear
    Exterior and Interior: Free choice of colours and interior finishing, Instrument panel with circular type instruments, rev. Counter, speedometer up to 400 km/h., middle console with display for several indication functions, air conditioning, velour carpeting, sport seats and three point safety belts. Tinted glass fitted as standard. Full leather upholstery optional.
    Dimensions and Weight: length: 4.120 mm
    width: 2.080 mm
    height: 1.120 mm
    ground clearance: 80 mm
    curb weight: circa 1.280 kg
    Design: Kurt Lotterschmid
    Delivery time: on request
    Preis: on request
    Miscellaneous: subject to alterations
  2. #2 Prophecy, Mar 22, 2007
    Year 2001
    Engine 6 litre V12 Twin turbo
    Transmission 5-speed manual
    Max speed 248 mph
    0-60 mph 3.7 seconds
    Horsepower 850 bhp @ 6000 rpm
    weight 1279 kgs / 2820 lbs
    http://www.diseno-art.com/encyclopedia/vehicles/road/cars/lotec_sirius.html
    "The Lotec Sirius could be manufactured and sold as a production super car if the funding was available to get the project up and going. As it is it remains a one-off fully working concept.
    Powered by the same 6 litre V12 used in the Pagani Zonda C12S, but with two KKK K27 turbochargers running at 0.85 bar, the Lotec Sirius makes 850 bhp @ 6000 rpm, and 737 ft lbs of torque @ 3800 rpm."
  3. #3 Prophecy, Mar 22, 2007
    Make Lotec
    Model Sirius
    Year 2001
    Models Produced 1
    Engine Location Mid
    Drive Type Rear Wheel
    Weight 2820 lbs | 1279.2 kg
    Top Speed 248 mph / 399 km/h
    Engine Cylinder Configuration V12
    Aspiration/Induction Twin-turbocharged
    Displacement 5987.00 cc | 365.3 cu in. | 6 L.
    Valves 48 / 4 per cylinder.
    Horsepower 1334.00 BHP (981.8 KW) @ 6300.00 RPM
    Torque 958.00 Ft-Lbs (1299 NM) @ 3400.00 RPM
    HP to Weight Ratio 2.1 LB / HP (Vehicles with similar ratio)
    HP / Liter 222.3 BHP / Liter
    Bore 3.86 in | 98 mm.
    Stroke 3.16 in | 80.3 mm.
    Compression Ratio 8:6:1
    Transmission 5 Speed Manual
    Seating Capacity 2
    Length 162.001 in | 4114.8 mm.
    Width 82.001 in | 2082.8 mm.
    Height 44.001 in | 1117.6 mm.
    Ground Clearance 80.001 mm | 3.1 in.
    Brakes Brembro Discs
    Tires Michelin Pilot Sport
    http://www.conceptcarz.com/vehicle/z6231/Lotec_Sirius/default.aspx
  4. #4 26y4u, Mar 23, 2007
    it has a 6-speed gearbox, read on the lotec website! otherwise it seems to be ok!
    if someone is right about the specs about this car, it is lotec themselves! and the site is available in english!!! yay!!!
  5. #5 ETB4U, Apr 27, 2007
    Here is a video of it:
  6. #6 Dragonspirit, Jun 13, 2008
    Thanks for those statistics man even though you copied and pasted, so what dude! Oh their website kicks ass, I even more now so than ever want one BIG TIME!!! Please don't ever let up man no matter what people on here say, too bad I'm not a fellow countryman, though. Swedes kick ass with having Lotec and Koenigsegg! Oh, I think I read carefully that production is already under way, right, or did I miss read about that?
  7. I definitely have some respect for this car. I just wish they would make at least a production run of 50.
