Re: No Subject <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from 123456789101</i> <b>viper is way better than this shit </b></blockquote><center><hr width="90%"></center><!-- END QUOTE --> You can't compare a Viper with this!!! You worhtless, useless, cocksucking, shit-eating, son of a *****!<!-- Signature -->
Re: No Subject hey, guys, how about we just admit that both the viper and m3 are amazing cars in their own respects? they are not built with the same ideas in mind: viper - brute sports muscle car. built for high-torque, high displacement, straight-line performance. a 2-seater powerhouse built to make your eyes pop out the back of your head. m3 - german engineering through and through. balance of cultivated performance, luxury, and just enough daily-driver practicality (4-seater, comfortable, acceptable cargo, etc.). sure, a viper could smoke it off the line, and for the most part on the track, but do you really want to feed a 500 cu monster v-10 for your commute to work (and the occasional "spirited" trip through the mountains)? 2 excellent cars, 2 totally different classes.
Re: No Subject <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from hslabbert</i> <b>hey, guys, how about we just admit that both the viper and m3 are amazing cars in their own respects? they are not built with the same ideas in mind: viper - brute sports muscle car. built for high-torque, high displacement, straight-line performance. a 2-seater powerhouse built to make your eyes pop out the back of your head. m3 - german engineering through and through. balance of cultivated performance, luxury, and just enough daily-driver practicality (4-seater, comfortable, acceptable cargo, etc.). sure, a viper could smoke it off the line, and for the most part on the track, but do you really want to feed a 500 cu monster v-10 for your commute to work (and the occasional "spirited" trip through the mountains)? 2 excellent cars, 2 totally different classes.</b></blockquote><center><hr width="90%"></center><!-- END QUOTE --> i wouldn't mind a viper for work...might be fun but i'd take the M3 over the viper any day... i'm no fan of domsetics... can't stand their QC, i mean, really, a gray plastic interior on a $70000 car? i don't think so... besides, the m3 is cheaper and has more than good enuf performance enuf to kick your average c5 vette ass<!-- Signature -->
Re: No Subject I Dont think so but still this car is nice, but the viper is way better!!!!! Year 2003 Origin Not Available Make Dodge Base Price $100 000 USD Model Viper Competition Coupe Production Not Available Engine & Transmission Body / Chassis Position Longitudinal Front Engine Drive Wheels RWD Configuration V10 Curb Weight 1361 kg / 3000 lbs Valvetrain OHV 2 Valves / Cyl Length 4676 mm / 184.1 in Displacement 8275 cc / 505.0 cu in Width 1961 mm / 77.2 in Power 387.8 kw / 520.0 bhp @ 5600 rpm Height 1186 mm / 46.7 in Torque 732.14 nm / 540.0 ft lbs @ 4600 rpm Wheelbase 2510 mm / 98.8 in Bore 102.36 mm / 4.03 in Front Track F 1565 mm / 61.6 in Stroke 100.6 mm / 3.96 in Rear Track R 1641 mm / 64.6 in Redline 6100 Steering Rack & Pinion w/Power Assist HP / Liter 62.84 bhp per litre Body / Frame Composite Body Panels HP / Curb Weight Front Brakes 18.0 Gear Type Tremec T-56 6-Speed Manual Front Brake Size Not Available 1st Gear Ratio 2.66:1 Rear Brakes Brembro Vented Discs w/ABS, Power Assist & 4 Piston Calipers 2nd Gear Ratio 1.78:1 Rear Brake Size Not Available 3rd Gear Ratio 1.30:1 Front Wheels F 45.7 x 27.9 cm / 18.0 x 11.0 in 4th Gear Ratio 1.00:1 Rear Wheels R 48.3 x 35.6 cm / 19.0 x 14.0 in 5th Gear Ratio 0.74:1 Front Tires P305/35ZR18 6th Gear Ratio 0.50:1 Rear Tires P345/30ZR19 7th Gear Ratio Not Available Front Suspension Independant Unequal Upper & Lower A-Arms w/2.25in Race Springs, Final Drive Ratio 3.07:1 Rear Suspension Independant Unequal Upper & Lower A-Arms w/2.25in Race Springs, Performance Top Speed 309.0 kph / 192.0 mph 0 - 60 mph 3.8 seconds 0 - Å mile 11.8 seconds 0 - 100 mph 9.2 seconds Lateral Acceleration 1.25g EPA City/Hwy 520.0 his viper is much better in prefomance, like I said its still a nice car!!
Re: No Subject <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from Lamboboy</i> <b>I Dont think so but still this car is nice, but the viper is way better!!!!! Year 2003 Origin Not Available Make Dodge Base Price $100 000 USD Model Viper Competition Coupe Production Not Available Engine & Transmission Body / Chassis Position Longitudinal Front Engine Drive Wheels RWD Configuration V10 Curb Weight 1361 kg / 3000 lbs Valvetrain OHV 2 Valves / Cyl Length 4676 mm / 184.1 in Displacement 8275 cc / 505.0 cu in Width 1961 mm / 77.2 in Power 387.8 kw / 520.0 bhp @ 5600 rpm Height 1186 mm / 46.7 in Torque 732.14 nm / 540.0 ft lbs @ 4600 rpm Wheelbase 2510 mm / 98.8 in Bore 102.36 mm / 4.03 in Front Track F 1565 mm / 61.6 in Stroke 100.6 mm / 3.96 in Rear Track R 1641 mm / 64.6 in Redline 6100 Steering Rack & Pinion w/Power Assist HP / Liter 62.84 bhp per litre Body / Frame Composite Body Panels HP / Curb Weight Front Brakes 18.0 Gear Type Tremec T-56 6-Speed Manual Front Brake Size Not Available 1st Gear Ratio 2.66:1 Rear Brakes Brembro Vented Discs w/ABS, Power Assist & 4 Piston Calipers 2nd Gear Ratio 1.78:1 Rear Brake Size Not Available 3rd Gear Ratio 1.30:1 Front Wheels F 45.7 x 27.9 cm / 18.0 x 11.0 in 4th Gear Ratio 1.00:1 Rear Wheels R 48.3 x 35.6 cm / 19.0 x 14.0 in 5th Gear Ratio 0.74:1 Front Tires P305/35ZR18 6th Gear Ratio 0.50:1 Rear Tires P345/30ZR19 7th Gear Ratio Not Available Front Suspension Independant Unequal Upper & Lower A-Arms w/2.25in Race Springs, Final Drive Ratio 3.07:1 Rear Suspension Independant Unequal Upper & Lower A-Arms w/2.25in Race Springs, Performance Top Speed 309.0 kph / 192.0 mph 0 - 60 mph 3.8 seconds 0 - Å mile 11.8 seconds 0 - 100 mph 9.2 seconds Lateral Acceleration 1.25g EPA City/Hwy 520.0 his viper is much better in prefomance, like I said its still a nice car!!</b></blockquote><center><hr width="90%"></center><!-- END QUOTE --> i'd still take this over a Viper any time of the day..... cuz it's an M3,,way better looking<!-- Signature -->
Re: No Subject <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from 123456789101</i> <b>viper is way better than this shit </b></blockquote><center><hr width="90%"></center><!-- END QUOTE --> I'm getting so tired of seeing this in every topic I get in to. Viper is a totally different car then a BMW, a Viper was never intended to compete a BMW. As stated before. Grow up. keep the faith<!-- Signature -->
Re: No Subject <!-- QUOTE --><center><hr width="90%"></center><blockquote><i>Quote from 123456789101</i> <b>viper is way better than this shit </b></blockquote><center><hr width="90%"></center><!-- END QUOTE --> Guys, don't make fun of this guy, he is obvioulsy mentally handicaped and partially brain dead. I'm impressed he posted anything at all! Angus<!-- Signature -->
Re: No Subject m3 coupe would absolutely destroy the viper in handling. this car on a track is high speed with amazing handling. one of the best handling cars in the world right now i would definitly say.<!-- Signature -->
