Norris Design EVO 9: updated
Discussion in 'Modified / Tuned Cars' started by JOEVXR, Oct 15, 2008.
  1. #1 JOEVXR, Oct 15, 2008
    Norris Design EVO 9
    Back in 2005 Norris Design built the wildest EVO ever - a 928BHP, two-door, short wheel base monster capable of hitting 60mph in 2.4 seconds, 100mph in 4.3 and carrying on to 201.42mph. Frustrated by constent transmission problems and complications and breakages. Owner Simon Norris and his team spent the last 6 months stripping down and re-building and innovating the ballistic bogey for the 2009 Time Attck season.
    Now the EVO 9 features a longitudinally mounted engine and mated to a £12,500 Holinger RDS-S six speed sequential gearbox, this then uses stronger, cheaper Skyline GT-R differentials and transfer box to mantain 4WD with a better weight distribution.
    " the best on the 1/4 mile has been 9.26 seconds at 160mph, but that featured plenty of wheelspin. hopefully i'll be able to get into the eight's with the new setup"
    videos of there 2005 setup:
    http://www.norrisdesigns.com/videos-evo9.asp
    full spec: http://www.norrisdesigns.com/demo9.asp
  2. Norris Design EVO 9
    dunno if the 2009 spec car is going to upload but spy pics can be found on there home page....looks sick
  3. Norris Design EVO 9
    Nuts. That would've been such a tight Group B rally car if that was still allowed.
  4. Norris Design EVO 9
    900 bhp = probably something like a GT42R = OMG LAG OLOLOLOLOLOLOL
  5. Norris Design EVO 9
    you can do an endless amount of body/chasis work
    you can put in a whole new tranny
    you can pull 9xx hp out of the engine
    why the hell cant u paint the hood and the bumper the same color as the rest of the car?
  6. Norris Design EVO 9
    hahaha
  7. Norris Design EVO 9
    I really like the evo as a two door. I still dont understand why Mitsubishi never produced a low slung coupe with the evo drivetrain. It would have made a great top trim for the eclipse, replacing the old GSX
  8. Norris Design EVO 9
    exactly
  9. Norris Design EVO 9
    Haha, not like the old Group B cars didn't have that...
  10. Norris Design EVO 9
    i dont get cars like this.
    Why dont they just build their own car if they're gonna replace almost everything in the old one?
  11. Norris Design EVO 9
    +million.
  12. Norris Design EVO 9
    because people know evos.
  13. Norris Design EVO 9
    that was made a while ago, like in '04 or something, sweet though
  14. Norris Design EVO 9
    Is the driver an American? Cause if the track gets bendy he doesn't know what to do.
    I know it's a big hp car but he is rubbish
  15. Norris Design EVO 9
    im pretty sure simon norris is british. and they have been doing well in the Time Attack series, which is more than just quarter miles.
  16. Norris Design EVO 9
    Where's Chuck Norris?..
  17. updated pics and specs
    Power: 950bhp & 700lb-ft with 9250rpm rev limit
    Weight 1180Kg (Dry)
    Top speed: 215mph + (201.43mph so far )
    Best 0-60mph = 2.4 sec
    Best 0-100mph = 4.3 sec
    Best 0-150mph = 8.00 sec
    � mile in 9.26 sec @160.09mph on 17" Nitto 555R tyres.
    Best 30-130mph = 5.06 sec
    (All times recorded at Santa Pod drag strip )
    Engine
    ND 2.24L long rod high deck engine mounted longitudinally, ND version 4 big valve cylinder head, ND solid profile camshafts, ND solid lifters, HKS vernier cam pulleys, GT4294R turbocharger, Single Tial 44mm external wastegate, Shearer custom exhaust manifold, ND custom 5� turbo inlt pipe, 1100hp K&N air filter, ND modified DI inlet manifold, Audi RS6 DBW throttle body, ND 9 litre high volume sump, ND accusump system (motec controlled), ND custom breather system, 3.5� silenced side exit exhaust system or 4� straight through side exit exhaust system.
    Cooling
    ND aluminium high volume custom radiator, twin 11� fans kit, ND pressurised header tank water system with Statnt 1.5 bar cap, Ralliart thermostat, ND 1260Hp rated intercooler, ND custom 3.5� intercooler pipework, ND 25 row oil cooler kit.
    Fuelling
    4 x std 560cc injectors, 4x 1200cc ND injectors, SARD dash 8 large fuel regulator, DI 8 injector fuel rail, ND custom aluminium low level fuel tank, twin bosch 044 in tank fuel pumps, pre and post filters, Twin dash 8 fuel feed lines with single Dash 8 return.
    Electronics
    ND 5 Bar map sensor, Motec M800 bold box, ND full CDi system with coil on plug top plate, ND custom engine and full chassis loom, Armtech battery isolater system, Electronic fire extinguisher system, small race battery, Motec shift light module.
    Transmission
    Holinger RD6-S 6 speed sequential transmission, Sfi approved thick wall custom drag bellhousing, ND weighted gear shift knob, ND triple plate clutch, Holinger digital gear indicator, Fully selectable split 4WD system, Skyline GTR transfer box, Skyline GTR modified front diff unit, Skyline GTR rear diff unit, Carbonetic carbon front and rear 1.5 way diffs, Custom driveshafts all round, custom front prop, custom rear prop, ND big rear wheel bearing modification.
    Suspension/Chassis
    AST 3 way suspension system, ND custom front anti roll bar and arms, ND custom lower front suspension subframe to facilitate longitudinal engine position, Custom bulkhead mounted further back, Custom transmission tunnel with removable aluminium section for easy access, Cusco rear anti roll bar, ND custom 2.2 turns lock to lock lightweight steering rack, DC electronics electric power steering system, polybushes throughout, Hyper Zero 9.5� x 18� wheels (Dry), 285/35/18 Toyo R888 tyres (Dry), Volk CE28-N 9.5� x 18� wheels (wet), 265/35/18 Cut Toyo R888 tyres (Wet), Full vehicle air jack lifting system.
    Braking
    Brembo 8 pot metal matrix front callipers, 343mm Alcon front discs and bells, PF01 front brake pads, Brembo 8 pot metal matrix rear callipers, 325mm custom rear brake discs and bells, DS4000 rear brake pads, Tilton bulkhead mounted race pedal box, Billet hydraulic handbrake, Dash 4 brake lines, Castrol SRF race fluid, electronic line lock (steering wheel operated), Tilton brake bias valve.
    Styling
    Unique 2dr short wheel base shell (10� shorter), 3� roof chop, Tubbed front and rear arches for wheel clearance, Load bearing T45 full roll cage, Voltex Cyber Evo front bumper, full carbon undertray, canards and oil cooler guide, E9 MR front �black� lights, Carbon wide front wings, clear side repeaters, custom carbon bonnet with bulge for engine clearance, ND custom shortened C west side skirts, Carbon wing mirrors, ND custom carbon roof skin, wide steel rear arches, Carbon bootlid, Voltex Cyber Evo rear high level GT spoiler, ND custom rear diffuser integrated into std E9 rear bumper, Drag Simpson parachute and mounting, Kawasaki three stage pearl Green paint scheme, lexan side and rear windows, custom glass front windscreen, ND single wiper conversion.
    Interior
    ND custom dashboard, HKS 2.5 bar Boost gauge, HKS oil pressure gauge, 4WD pressure gauge, Stack race dash, Recaro Profi SP-A carbon kevlar seats, Sabelt HANS ready 5 point harness�s, ND custom carbon door cards, ND custom carbon fuel tank cover, Carbon � panels, carbon boot floor panels, carbon boot side panels, Race steering wheel.
  18. #18 JOEVXR, Jan 4, 2009
    actually ithink your right....
  19. #19 countdown, Jan 4, 2009
    lol what the hell, why did he hit the accelerator?
  20. #20 superserge, Jan 4, 2009
    jesus christ
  21. #21 zzUltimaGTRzz, Jan 5, 2009
    My GOD this car is sick! I want one! Do you think it could beat this time attack record set at Tsukuba by the HKS CT230R (much lower hp)?
    (record lap begins @ 3:42):
