Nurburgring Lap Times
Discussion in 'Car Comparisons' started by ajzahn, Oct 28, 2004.
  1. lol GT-R is faster!
  2. lol GT-R is on semi-slicks (that's why it's faster)
  3. direct comparo:
    7:41,2 min - Porsche 911 Turbo S Aerokit
    7:43,7 min - Nissan GT-R MY10
  4. And from Horst von Saurma:
    7.34 min - GT-R MY11, 530 hp, semi-slicks
    7.44 min - 911 Turbo S, 530 hp, stock-tyres
  5. ^butthurt because the GT-R is faster than their precious vw beetle^
  6. Still, on semi-slicks <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/wink.gif"></A>
  7. #2132 steesyAcelupt, Feb 19, 2011
    flanger.edu.ms]http://flanger.edu.ms]flanger.edu.ms[/url][/url]
    Map]http://flanger.edu.ms/map.html]Map[/url][/url]
    Map]http://flanger.edu.ms/map10.html]Map[/url][/url]
    Map]http://flanger.edu.ms/map5.html]Map[/url][/url]
    turbo flange wide flange h-beam weights turbo flange sizes ramco flange guard flange roller chain asa flange dimensions flange 5k dimension ibanez flanger manufacturer metric flange nut pipe flange loading flange guards shields npt flange thread parrall national flange inc portable flange facer carbon steel flanged fittings flange of baboons taylor forge flange circulating pump flange dimensions web flange non-standard lap joint stub end flange toilet flange extension red rock flange tester 60 bolt flange torque sequence asme flange bolt sizes flange pipe support small flange mount bearings flange isolation kit houston full face flange jis flange specifications closet flange installation height
    flange]http://flanger.edu.ms/serrated-hex-flange-nut/flange-mounted-demister-support.html]flange mounted demister support[/url]
    flange]http://flanger.edu.ms/toilet-flange-buster-tool/page-941.html]flange reducer bushing[/url]
    flange]http://flanger.edu.ms/toilet-flange-height-wax-ring/doc_1150.html]flange weights 600[/url]
    coupling]http://flanger.edu.ms/mxr-flanger-pedal/doc_1835.html]coupling flange holder[/url]
    flange]http://flanger.edu.ms/kerkau-manufacturing-flange/page_4160.html]flange rtj size[/url]
    texas]http://flanger.edu.ms/serco-flange-facing-machines/texas-flange-and-fitting-supply.html]texas flange and fitting supply[/url]
    flange]http://flanger.edu.ms/flange-bolt-circle-diameter/page_216.html]flange block bearing[/url]
    central]http://flanger.edu.ms/flange-class-rating/doc_4600.html]central flange insulation[/url]
    exhaust]http://flanger.edu.ms/toilet-flange-height-wax-ring/exhaust-flange-repair-clamp.html]exhaust flange repair clamp[/url]
    flange]http://flanger.edu.ms/flange-ansi-dimension/flange-leveling.html]flange leveling[/url]
    flange]http://flanger.edu.ms/flange-pn16-size/flange-uses.html]flange uses[/url]
    closet]http://flanger.edu.ms/ansi-flange-300/site-4019.html]closet flange repair plate[/url]
    flange]http://flanger.edu.ms/diy-toilet-flange-repair/site-3022.html]flange quilt[/url]
    flange]http://flanger.edu.ms/image-of-a-flange/page_147.html]flange 6 inch[/url]
    api]http://flanger.edu.ms/flange-welding-machine/page_3051.html]api flange loading[/url]
    flange]http://flanger.edu.ms/serrated-hex-flange-nut/page-3297.html]flange sealing[/url]
    flange]http://flanger.edu.ms/flange-lockout/page-2115.html]flange pedals[/url]
    flange]http://flanger.edu.ms/pipe-flange-torque-values/site-1001.html]flange font[/url]
    wide]http://flanger.edu.ms/flange-2500-lbs/page_3373.html]wide flange beam section[/url]
    stainless]http://flanger.edu.ms/pad-flange/page_88.html]stainless steel flange ratings[/url]
    what is a surrey flange beam flange loading raised face flange wikipedia taper-lok flange dimensions flange head screw india steel flange mount bearings large pipe flange dimensions ansi flange dimensions 1500 flange washer nut hex flange 8m 1.25 flange jis vs ansi welding flange pins uneven toilet flange metric hex head flange screws spec integral flange definition flange v-band flange skillets flange mount bushings split flange insert contax flange focal distance texas flange site flange bearing frog din flange gaskets flanger pedal schematic exhaust flange 3 inch wide flange steel column flange clamp design insulated flange tester analysis of flange joints under external loads flange facing equipment
    flange]http://flanger.edu.ms/4-flange-gate-valve/site-763.html]flange quick clamp[/url]
    closet]http://flanger.edu.ms/flange-vanstone/doc_876.html]closet flange repair[/url]
    t]http://flanger.edu.ms/removing-a-toilet-flange/page-4667.html]t mount flange focal distance[/url]
    hdpe]http://flanger.edu.ms/metric-flange-nuts-jis/page_2600.html]hdpe flange adapter[/url]
    flanger]http://flanger.edu.ms/flange-exhaust/flanger-effect-pedal.html]flanger effect pedal[/url]
    flange]http://flanger.edu.ms/slip-on-flange-drawing/flange-manufacturer.html]flange manufacturer[/url]
    pipe]http://flanger.edu.ms/brown-and-sharpe-flange-mount-pumps/page-1519.html]pipe flange bolting[/url]
    flange]http://flanger.edu.ms/flange-vanstone/flange-usa-manufacturer.html]flange usa manufacturer[/url]
    how]http://flanger.edu.ms/wide-flange-beam-section/page_3401.html]how to install toilet flange extender[/url]
    flange]http://flanger.edu.ms/metal-pipe-flange-gaskets/site-1418.html]flange specifications tap blind flange[/url]
    flange]http://flanger.edu.ms/flange-pn16/page-4527.html]flange element[/url]
    pipe]http://flanger.edu.ms/slip-on-flange-drawing/doc_4167.html]pipe flange applications[/url]
    cast]http://flanger.edu.ms/flange-slide-rule-online/cast-flange-backing-rings.html]cast flange backing rings[/url]
    ford]http://flanger.edu.ms/pipe-flange-6-inch/ford-88-flange-yoke.html]ford 8.8 flange yoke[/url]
    measure]http://flanger.edu.ms/flange-skillets/measure-cat-flange.html]measure cat flange[/url]
    pipe]http://flanger.edu.ms/pipe-flange-6-inch/pipe-flange-pressure-rating.html]pipe flange pressure rating[/url]
    pipe]http://flanger.edu.ms/single-flange-wheels/page_491.html]pipe flange ansi[/url]
    flange]http://flanger.edu.ms/pad-flange/doc_3080.html]flange jis[/url]
    toilet]http://flanger.edu.ms/pipe-flange-pressure-to-temperature-ratings/toilet-flange-height-tile.html]toilet flange height tile[/url]
    flange]http://flanger.edu.ms/serrated-hex-flange-nut/doc_3043.html]flange isolanti[/url]
    extended disposal flange nashville tn asme flange thickness flange welding equipment flange plunger unclog van stone bend flange flange louvered vents pipe flange how work toilet flange 90 degree walker flange repair kit audi coolant flange 2002 weld neck flange weights loctite 5910 flange sealant flange inconel flange wizard cutting guide american flange manufacturing co inc 3 pvc flange fitting flange leak detection sealmaster flange bearings bolt and flange chart fix leaking toilet flange on concrete reversible spectacle blind flange high box flange din flange material puddle flange wikipedia flange bolt patterns rough in a new toilet flange jis flange 10k rubber flange seal canon flange focal distance rpm flange data
    flanger]http://flanger.edu.ms/pipe-flange-6-inch/page_1066.html]flanger train[/url]
    flange]http://flanger.edu.ms/toilet-flange-buster-tool/page-3918.html]flange bolt torque calculation[/url]
    4]http://flanger.edu.ms/flange-hydraulic-fittings/page-936.html]4 pvc flange fitting[/url]
    texas]http://flanger.edu.ms/buffalo-flange-houston/texas-flange-forging.html]texas flange forging[/url]
    parallel]http://flanger.edu.ms/flange-2500-lbs/parallel-flange-channel-table.html]parallel flange channel table[/url]
    harley]http://flanger.edu.ms/flange-gate-valves-civ/page_676.html]harley exhaust flange kit[/url]
    audi]http://flanger.edu.ms/national-flange-usa/page_624.html]audi coolant flange 2002[/url]
    luken]http://flanger.edu.ms/metric-flange-nuts-jis/page-945.html]luken flange[/url]
    trip]http://flanger.edu.ms/removing-a-toilet-flange/page_2298.html]trip lever flange toilet[/url]
    installing]http://flanger.edu.ms/flange-gate-valves-civ/doc_4368.html]installing toilet flange height[/url]
    metal]http://flanger.edu.ms/piping-flange-gasket-reference/page_3872.html]metal flange caps[/url]
    aluminum]http://flanger.edu.ms/wide-flange-i-beam/site-1741.html]aluminum trailer wide flange[/url]
    orifice]http://flanger.edu.ms/piping-flange-gasket-reference/page_793.html]orifice flange[/url]
    4]http://flanger.edu.ms/flange-2500-lbs/page-3264.html]4 flange bolt pattern[/url]
    thin]http://flanger.edu.ms/split-flange-seals/site-1187.html]thin wall flange on pipe[/url]
    flange]http://flanger.edu.ms/flange-protection-covers/flange-bearing-catalog.html]flange bearing catalog[/url]
    browning]http://flanger.edu.ms/flange-slide-rule-online/doc_1526.html]browning flange bearings[/url]
    flange]http://flanger.edu.ms/flange-specifications-tap-blind-flange/page_1123.html]flange torque charts[/url]
    toilet]http://flanger.edu.ms/removing-a-toilet-flange/toilet-flange-hieght.html]toilet flange hieght[/url]
    metric flange bolt assortment flange jis 5k brown and sharp flange mount pumps pipe flange selection flange pedal floor receptacle with carpet flange din flange sizes pvc flange specs flange pcd definition rtj flange specs flange protectors houston texas wide flange wiki bop axle flange 6 flanged gate valve slip on flange pn16 rv toilet mounting flange flange sizes metric insulating flange flange bolt kits sizes toilet flange installation new construction replace flange unit how to replace toilet flange ansi flange 150 lb flange plate adapters flange nozzle flange oil industry petroleum exhaust flange 3sgte medela flange fit flanger schematic buffalo flange inc houston tx
    flange]http://flanger.edu.ms/flange-guide-pins/site-176.html]flange ansi standard[/url]
    stainless]http://flanger.edu.ms/flange-bearing-cross-reference/page_2898.html]stainless steel flange gaskets in china[/url]
    flange]http://flanger.edu.ms/installing-flange/page_4274.html]flange 3d bend[/url]
    wide]http://flanger.edu.ms/flange-exhaust/page_4012.html]wide flange beam rental[/url]
    flange]http://flanger.edu.ms/brown-and-sharpe-flange-mount-pumps/site-1266.html]flange finish 125 250 aarh[/url]
    double]http://flanger.edu.ms/flange-exhaust/doc_2910.html]double flange eartips[/url]
    exhaust]http://flanger.edu.ms/quick-fix-closet-flange-extension-kit/page-3444.html]exhaust flange repair chevy[/url]
    6]http://flanger.edu.ms/pump-flange-sizing/page_1136.html]6 flanged gate valve[/url]
    flange]http://flanger.edu.ms/flange-wizard-products/site-2534.html]flange leakage[/url]
    flange]http://flanger.edu.ms/flange-leak-repair-clamp/doc_3090.html]flange focal distance wiki[/url]
    flange]http://flanger.edu.ms/rubber-pipe-flange-gaskets/page_1751.html]flange bolt torque table[/url]
    flange]http://flanger.edu.ms/removing-a-toilet-flange/flange-thickness-calculator.html]flange thickness calculator[/url]
    british]http://flanger.edu.ms/repair-flange-for-toilet/site-126.html]british pipe company flange insulator[/url]
    hex]http://flanger.edu.ms/ansi-flange-300/doc_1695.html]hex flange nut nylon[/url]
    anchor]http://flanger.edu.ms/texas-flange--fitting-supply/site-4289.html]anchor flange co[/url]
    socket]http://flanger.edu.ms/web-flange/page_364.html]socket button flange[/url]
    flange]http://flanger.edu.ms/4-flange-gate-valve/site-4284.html]flange 64[/url]
    m8]http://flanger.edu.ms/flange-pn16-size/page_1885.html]m8 serrated flange nut[/url]
    flange]http://flanger.edu.ms/flange-exhaust/page_297.html]flange torque sequence[/url]
  8. then why hasnt anyone put semi-slicks on the 911 turbo to see how it goes?
    ill tell you why
    because they're scared they will lose!
  9. No, because most of the 911 Turbo-customers won't use their cars for trackdays.
  10. #2135 Ensuegebuby, Feb 20, 2011
  11. Next iussue?
  12. Then why was the 997.1 Turbo tested on Pilot Sport Cups?
  13. Ask Porsche or Sport Auto.
  14. even so, the 997 pdk @ Ring with sport auto, had only 4 optionals: Sport cup, Sport ccrono, hard setup and composite brakes <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/wink.gif"></A>
    mnfrs sometimes puts on test extreme (but still legal) equipments (SLS too, see the opionals list on Sport Auto during the supertest), sometimes not (ex. GT-R tested @ Balocco tyres bridgestone, 997 PDK 385ps @ Vairano without sport chrono, or 997TT 480ps @ Vairano during a supercomapro tested "just" with Pilot Sport...)
    strange choices...
  15. I don't think I need to. The N-spec Bridgestone RE050s are not far off the ultimate grip of N-spec Pilot Sport Cups, according to the 911's project manager. And Walter Rohrl says ~5 seconds on the Ring. The tires are not the big differentiator that you're making them out to be. I'd say other factors make a bigger difference. The 997.1 Turbo had problems with the balance of its AWD system and perhaps that still persists with the 997.2. On the 'Ring, where you need high-speed stability, a longer wheelbase helps. The Turbo's, at 2350mm, is only 20mm longer than a Miata. The GT-R's is 430mm longer, within 20mm of an MC12's.
    I'm not sure how the weather is at the 'Ring this time of year. It's probably a bit cold, I'd imagine.
  16. Lamborghini Gallardo LP570-4 Superleggera <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/wink.gif"></A>
  17. rumor time from autocar for mp4-12c
    just over 7 minutes!
    WOW
  18. #2143 ajzahn, Mar 1, 2011
  19. nice <A BORDER="0" HREF="http://www.supercars.net/PitLane?displayFAQ=y"><IMG BORDER="0" SRC="pitlane/emoticons/smile.gif"></A>
  20. #2145 Orgariema, Mar 2, 2011
    Я предпологал это такого не может быть и до меня дошло! Кстати здравствуйте, для начала и после уже приступим к работе. Вобщем такая уматовая по моему мнению статья! Нашёл в интернет просторах портал: бермудский]http://www.stolichnyi.com/mystic/72-gigantskie-piramidy-v-bermudskom-treugolnike.html]бермудский треугольник фото[/url] и предлагаю вам его посетить. Меня смутил там сам смысл сайта! он какойто не понятный и мне чувствуется, что я попал в точку. Как Вам данный портал и что Вы можете о нём написать? Жду вашей хлоднокровной критики по этому интернет ресурсу.
  21. В бескрайнем океане досуговых ресурсов x-stars.ru совсем не простая рыбка, а скорее огромный кит. На страничках x-stars.ru Вы сможете найти, все что Вам необходимо для красивого досуга, это шикарные проститутки, которые предложат свои услуги по реальным ценам. Любой получит подходящий вариант в соответствии со своими запросами. Исключительно реальные фото и исключительно настоящие проститутки. Берите от своей жизни все, отдыхайте с наслаждением. Наш список обновляется ежедневно и вы можете не сомневаться, что в тот момент, когда у вас появилось желание, вы можете отыскать приглянувшуюся вам индивидуалку на нашем интернет-ресурсе.
  22. Suck my balls.
  23. Here is my story:
    Back in the winter of 2006 I was just getting back to dancing to try and lose the 25 extra pounds
    I had gained after medical school, but it was really hurting my knees.
    Then a fellow doctor who is also a nutritionalist turned me on to Hoodia Gordonii Pills.
    All the lecture about antioxidant this, and that, didn’t really mean much to me,
    but I trusted my friend and gave it a try. Well, what do you know – within a week,
    my joints did start to feel a LOT better. So, I kept taking the pills, dancing and starting to loose weight.
    The more I learned the better it gets
    Then I started reading about how Hoodia is being used by all these hollywood celebrities as a DIET aid.
    Then I saw a commercial on CBS and ABC.
    I did A LOT of research and found a site with the best prices AND guaranteed return policy is: Here...-->
    a 4 month order.
    It'll work trust me. It has worked for 5 of my buddies.
    I got some Hoodia pills and started taking 2 of those in the afternoon.
    That helped keep me from getting hungry late in the day and hitting the junk food machine at work.
    Read more...
  24. #2149 ajzahn, Mar 18, 2011
    latest addition to the list:
    7:38 --- 161.63 km/h- Lamborghini Gallardo LP 570-4, 570 PS/1493 kg (sport auto 03/11)
    lines up with:
    7:38* -- 161.63 km/h - Lexus LFA, 560 PS/1598 kg (sport auto 09/10)
    7:38* -- 161.63 km/h - Mercedes SLR 722 GT, *company test driver Chris Goodwin www.auto-motor-und-sport.de/news/auto_-_produkte/hxcms_article_507671_13987.hbs
    7.38* -- 161.63 km/h - Nissan R35 GT-R, *company test driver Suzuki, slick cut tyres, track partially wet www.edmunds.com/insideline/do/Features/articleId=123066?tid=edmunds.il.home.photopanel..1.*#40
    7.38 --- 161.63 km/h - Chevrolet Corvette ZR1, 647 PS/1533 kg (sport auto 10/09)
    7.38 --- 161.63 km/h - Ferrari 458 Italia, 570 PS/1540 kg kg (sport auto 08/10)
    7.38 --- 161.63 km/h - Nissan GT-R, 486 PS/1778 kg (sport auto 07/09)
    7.38* -- 161.63 km/h - Porsche 997 Turbo *back-to-back testing by Porsche www.autocar.co.uk/News/NewsArticle/Nissan-GT-R/235197/
    7:38.85 161.59 km/h - Lexus LFA, 560 PS/1580 kg (AutoBild Sportscars 10/10)
    7.39 --- 161.58 km/h - Ferrari 430 Scuderia, 510 PS/1402 kg (sport auto 07/08) http://www.supercars.net/PitLane?viewThread=y&gID=0&fID=2&tID=160225
    7.39* -- 161.58 km/h - Porsche 997 GT3, 415 PS/1395 kg, *mfr. (quote sport auto 05/06)
    7:39 --- 161.58 km/h - Koenigsegg CCR, 806 PS/1180 kg
    impressive figures!
