Official Koenigsegg Specs
Discussion in '2002 Koenigsegg CC 8S' started by SupraMan, Sep 13, 2003.
  1. #1 SupraMan, Sep 13, 2003
    These are from the site: www.koenigsegg.com
    Specifications
    Body
    Coupe/Convertible (stow able hardtop). Pre-impregnated carbon fibre, Kevlar and lightweight hardfoam sandwich construction. Aerodynamic drag co-efficiency: 0.29 Cd. There is a 120 litre forward compartment for luggage.
    Chassis
    Koenigsegg integrated semi-monocoque. Pre-impregnated carbon fibre (woven and unidirectional) and aluminium honeycomb sandwich construction.
    Stiffness: 28.100 nm/degree.
    Engine
    Koenigsegg developed semi-stressed, mid mounted supercharged and intercooled 32-valve quad cam alloy 4.7 litre 8 cylinder (90 degree V formation).
    Max. power output 655 hp at 6,800 rpm
    Max. torque 750 Nm at 5,000 rpm
    Redline at 7,500 rpm
    Dry-sump oil lubrication with Setrab oil to air cooler, oil spray cooled forged pistons and connecting rods, sequential fuel injection, OBDII, non-return fuel system with large bore aluminium extruded fuel rails. Step tube stainless steel full length exhaust manifold with fire-cone collectors, 4 stainless steel metal catalytic converters, and carbon fibre induction type air intake with conical oiled organic air filter, carbon fibre valve and timing covers.
    Fuel consumption: Highway travel: 9 lt/100km, combined consumption: 14 lt/100 km.
    Transmission
    Six-speed transaxle gearbox with internal oilpump and external Setrab air to oil cooler, torque sensitive limited slip differential. Gear ratios: 1st 2.875:1, 2nd 1.772:1, 3rd 1.266:1, 4th 1:1, 5th 0.830:1, 6th 0.711:1, rev. 3:1.
    Final Ratio: 3.364
    Steering
    Rack and pinion 2.7 turns lock to lock
    Turning circle 11 meters
    Clutch
    Specially developed 215 mm AP-Racing 2 disc clutch with integrated starter ring.
    Suspension
    Double wishbone. Specially developed adjustable Öhlins gas-hydraulic shock absorbers, mounted according to the pushrod principle. Hydraulic ride height adjustment.
    Brakes
    Koenigsegg specially developed units with ventilated discs and aluminium bell-housings.
    Front 345 mm diameter, 32 mm wide, 6 calipers
    Rear 330 mm diameter, 30 mm wide, 4 calipers
    Wheels
    Special Koenigsegg magnesium alloy wheels
    Front, centre bolt 19” x 9.5”
    Rear, centre bolt 20” x 12.5”
    Tires
    Michelin pilot sport 2
    Front: 265/35 19" (y)
    Rear: 335/30 20" (y)
    Fuel capacity
    80 litres
    Standard equipment
    Leather upholstery, Driver side airbag, ABS, Power steering, Power brakes, Traction control Hydraulic ride height system, Climate control, Alarm with Immobilizer, Stereo with CD, electrical window, central locking, electrical rear view mirrors, Detachable hardtop, Car Cover, Tools.
    Extra equipment
    Custom Color Leather Interior, Custom Paint Color, Parking Sensors, GPS Navigation, Telephone System, Rearview Camera, Fitted Luggage, Extra sound insulation, 4 Point Safety Belts, Ceramic brake system, Twin fin wing / adjustable carbon splitternolder.
    Performance Data
    Acceleration 0-100 km/h, 0-62 mp/h under 3.5 sec.
    Top speed 390 km/h, 240 mp/h
    Quarter mile time 10 sec, end speed 217 km/h
    Lateral G 1.3 G
    Braking distance 100-0 km/h 32 meters
    Dry weight 1,170 kg
    Aerodynamic Cd value 0.29 with down force
    Dimensions
    Height 1,070 mm, 42.1’’
    Length 4,190 mm, 165’’
    Width 1,990 mm, 78.3’’
    Wheelbase 2,660 mm, 104.7’’
    Warranty
    Two years warranty, 10 years corrosion warranty.
    Service
    Full factory and retailer support. Service intervals: Oil, filter and general inspection (suspension geometry check) every 5,000 km. Sparkplug change every 10,000 km. Cooling fluid every 24 months. Brake fluid every 12 months. Retailers provide in-house service in the USA, Europe, and the Middle East. Koenigsegg has a flying mechanic on stand-by.
    A GSM satellite uplink can be provided, so engine statistics can be distance monitored from the local service station or the Koenigsegg HQ.
    Education
    Three days of high performance driving instruction with safety and technical education included.
    Koenigsegg reserves the right to change specifications without further notice.
