S2000 pulls to the right while braking???
Discussion in 'Technical' started by ronin, Aug 22, 2008.
  1. what side of the road do you drive on? cars are designed to slighty pull off the side of the road normally/when braking so say you fall asleap or someting, u just own yourself, not the poor kunt coming the other way
  2. road crown...
    also, I dunno if anyone said anything, but it could be something as simple as low tire pressure and braking multiplies the pulling to the right, if it was normally, slowly doing so at cruising..
  3. Ball joints/tie rod ends.
  4. My vote is with tire pressure or bad alignment, both of which are made worse the harder you brake due to weight transfer.
  5. We shall never know.
  6. yeah, only thing is tire pressure is very easy to fix and diagnose
  7. Hondas can't handle.
