Specifications for the 2004 MotoGP motorcycles
Discussion in 'Trucks and Motorcycles' started by Orange F1LM, Sep 12, 2004.
  1. Aprilia RS³ ‘Cube’
    overall length · 2030mm
    overall width ·
    overall height ·
    wheelbase · 1410mm
    road clearance ·
    weight · 135+ kg
    chassis · aluminium dual beam frame; aluminium or carbon swing-arm
    suspension · Öhlins inverted 42mm hydraulic forks front; APS progressive system, Öhlins adjustable shock rear
    brakes · Brembo: 290/320mm carbon discs front; 218m disc rear
    fuel tank · 24 litres
    tyres · Michelin
    wheels · magnesium alloy or carbon: 16.5" or 17" front; 16.5" rear
    engine type · liquid-cooled four-stroke
    displacement · 990cc
    cylinders · inline 3
    valve type · four valve
    carburation · digital electronic injection
    transmission · six-speed aluminium gearbox;
    ignition · digital electronic ride-by-wire
    maximum power · 220+ bhp at 15,000+ rpm
    maximum speed ·
    Ducati Desmosedici GP4
    overall length ·
    overall width ·
    overall height ·
    wheelbase ·
    road clearance ·
    weight · 148kg
    chassis · trellis-style tubular steel; pressed aluminium swing-arm
    suspension · Öhlins inverted 42mm forks front;
    brakes · Brembo: 320mm carbon discs, four-piston calipers front; stainless steel disc, two-piston caliper rear
    fuel tank ·
    tyres · Michelin
    wheels · 17" or 16.5" front; 16.5" rear
    displacement · 989cc
    cylinders · 90° V4
    valve type · desmodromic DOHC four valve
    carburation · Magneti Marelli: indirect electronic injection
    transmission · six-speed cassette-type gearbox; dry multi-plate slipper clutch
    ignition · Magneti Marelli
    maximum power · 230+ bhp at 16,500rpm
    maximum speed · 330+ km/h
    Harris WCM990
    overall length ·
    overall width ·
    overall height ·
    wheelbase · 1420mm
    road clearance ·
    weight · 145+ kg
    chassis · aluminium frame
    suspension · Öhlins inverted telescopic forks front; Öhlins monoshock rear
    brakes · AP: carbon discs and calipers front; ventilated disc and calipers rear
    tyres · Dunlop
    wheels · PVM: 16.5" front; 16.5" rear
    engine type · four-stroke
    cylinders · inline 4
    valve type ·
    carburation · fuel injection
    transmission · six-speed gearbox; dry multi-plate clutch
    ignition · CDI
    maximum power ·
    maximum speed ·
    Honda RC211V
    overall length · 2050mm
    overall width · 600mm
    overall height · 1130mm
    wheelbase · 1440mm
    road clearance · 130mm
    weight · 148+ kg
    chassis · twin-tube frame
    suspension · telescopic forks front; new unit pro-link rear
    brakes ·
    tyres · Michelin; Bridgestone
    wheels · 17" front; 16.5" rear
    cylinders · 75.5° V5
    valve type · DOHC four valve
    carburation ·
    transmission ·
    ignition ·
    maximum power · 240+ bhp
    maximum speed ·
    Kawasaki Ninja ZX-RR
    overall length · 1420mm
    overall width ·
    overall height ·
    wheelbase · 1330mm
    road clearance ·
    weight · 145kg
    chassis ·
    suspension ·
    brakes ·
    fuel tank ·
    tyres · Bridgestone
    wheels ·
    cylinders · transverse inline 4
    valve type · DOHC; cam drive by gear
    carburation ·
    ignition ·
    maximum power · 220+ bhp at 15,500rpm
    maximum speed ·
    Proton KR5
    overall length ·
    overall width ·
    overall height ·
    wheelbase · variable
    road clearance ·
    weight · 145kg approx
    chassis · alloy frame
    suspension · Öhlins forks front; Penske rear
    brakes · Nissin: carbon discs front; steel discs rear
    tyres · Dunlop
    wheels · Marchesini
    cylinders · 60° V5
    valve type ·
    carburation · multipoint programmable fuel injection
    transmission · six-speed sequential gearbox; dry multi-plate clutch
    ignition · programmable CDI
    maximum power · 200+ bhp at 15,000rpm
    maximum speed ·
    Suzuki GSV-R XRE2
    overall length · 2060mm
    overall width · 660mm
    overall height · 1150mm
    wheelbase · 1450mm
    road clearance ·
    weight · 145kg
    chassis · twin spar aluminium alloy frame
    suspension · inverted telescopic forks front; link type rear
    brakes · carbon discs front; steel or carbon disc rear
    tyres · Bridgestone
    wheels · 16.5" front; 16.5" rear
    engine type · water-cooled four-stroke
    cylinders · 65° V4
    carburation · electronic fuel injection
    transmission · six-speed constant mesh; dry multi-plate clutch
    ignition ·
    maximum power · 220+ bhp at 14,500+ rpm
    maximum speed ·
    Yamaha YZR-M1
    overall length ·
    overall width ·
    overall height ·
    wheelbase ·
    road clearance ·
    weight · 145kg
    chassis · multi-adjustable twin spar aluminium frame; braced aluminium swing-arm
    suspension · Öhlins adjustable inverted telescopic forks front; Öhlins shock, rising rate linkage rear
    brakes · Brembo: 320mm carbon discs, four-piston calipers front; 220mm ventilated stainless steel disc, twin-piston caliper rear
    tyres · Michelin
    wheels · Marchesini: 17" front; 16.5" rear
    valve type · 20-valve DOHC
    ignition · Yamaha CDI
    maximum speed · 320+ km/h
    my favorite is the Honda RC211V
    I like that its frame is designed from scratch unlike some of the others based on other bikes, also I like that it has a longer wheelbase and the driver sits down lower too. oh ya, 240 horsepower at 315 lbs is also nice.. look how nice it is below..
  2. the honda is a V5, two cylinders in the rear, 3 in the front, I think thats the front to back order.
  3. the proton entry - is that sort of like the mv agusta entry seeing proton bought the mv group?
