The McLaren F1 GT is not better then the normal one.
Discussion in '1997 McLaren F1 GT' started by Black Devil, Nov 7, 2002.
  1. And only 3 were build.
  2. Re: The McLaren F1 GT is not better then the normal one.
    *sigh*
  3. Re: The McLaren F1 GT is not better then the normal one.
    So what!
  4. Re: The McLaren F1 GT is not better then the normal one.
    Is that right?
  5. Re: The McLaren F1 GT is not better then the normal one.
    I don't think so and Gordon Murray,too!
  6. Re: The McLaren F1 GT is not better then the normal one.
    The HP is lower here and this 3 piece car has more Kilograms.
  7. Re: The McLaren F1 GT is not better then the normal one.
    Thaz what I just meant!
  8. Re: The McLaren F1 GT is not better then the normal one.
    What a wako idea.
  9. Re: The McLaren F1 GT is not better then the normal one.
    Well the GT version I believe has better handling and some improvements. The extended rear definately gives better handling through added downforce. It's like with the LM, it goes slower than the standard Mclaren because it drives better. And even in racing when can you take a car up to 240 any way?
  10. Re: The McLaren F1 GT is not better then the normal one.
    Better handling no way a GT has lower handling then F1!!!
  11. Re: The McLaren F1 GT is not better then the normal one.
    Noooo...the GT has of course a better handling for a track!
  12. Re: The McLaren F1 GT is not better then the normal one.
    Yes it is
  13. Re: The McLaren F1 GT is not better then the normal one.
    It has as much downforce as the LM but less drag. The GT would be faster around a track than the standard Mac F1
  14. Re: The McLaren F1 GT is not better then the normal one.
    Probably!-I think we all don't know!
    Thanx°°°
  15. Re: The McLaren F1 GT is not better then the normal one.
    Wrong, the GT has more downforce than the other McLaren F1's due to it's base being longer, a reasonably lower, the lower it is the more downforce. Downforce is really just how fast the air is moving under the car, the faster, the more downforce, causing the car to push down towards the ground. Dowforce is the backwards concept of the plane, which has to do with upforce, thats why it stays in the air.
  16. Re: The McLaren F1 GT is not better then the normal one.
    Exactly. Similar downforce as the Mclaren F1 Lm, but less drag through the use of a paneled underbody tray as opposed to the wing.
  17. Re: The McLaren F1 GT is not better then the normal one.
    And i own 2 of them.
  18. Re: The McLaren F1 GT is not better then the normal one.
    When will you SHUT UP!!!
    You've said many times that you own two F1 GT's.
    Do you really think any sane person would believe you?
    Just do everyone a favor and SHUT UP!
