1. is this REALLY a W16, the photo of the engine on this site and many others ive found make it look like a V16 rather than a W16
    look at the exhaust pipes going into the turbochargers, theres 8 of them in a line
    a W16 should be wider than it is long whereas this engine is long and thin like a V12
    any thoughts?
  2. Re: W16
    Why would they lie???
  3. Re: W16
    It is a W16. Its construction (as well as VW's other W-engines) is similar to VW's VR6 in that two banks of cylinders are covered by a single cylinder head with intake on one side and exhaust on the other. So, this W-16 will have four banks of cylinders and only two cylinder heads.
  4. Re: W16
    yes im aware of the construction, but just look at the engine photo, 8 exhausts in a line means 8 cylinders in a line which means V16
    photos of the W8 and W12 show an obvious W-shape
    an 8-litre W16 should only be marginally longer than a V8, i'd like to see someone try and fit this motor transversely under a Cadillac Seville's hood (normally 4.6 V8, and yes i know one's a VW and one's a Caddy, thats not the point)
  5. Re: W16
    Read my post again and you will note that after I said one cylinder head caps two banks of cylinders, I also stated that all the intakes are on one side of the cylinder head and all the exhausts are on the other side. So, on a VR6, you see six exhaust pipes coming out one side of the cylinder head right next to each other on what is a narrow-angle V6 (not inline-6) engine. The same thing is happening here. For the two banks of four cylinders (eight cylinders totdal) capped by the single cylinder head, you will see eight exhaust ports on one side of the head (thus eight exhaust pipes right next to each other), and eight intakes on the other side of the head.
  6. Re: W16
    well then ok
  7. Re: W16
    Sorry if that sounded rude. That wasn't my intention.
  8. Re: W16
    The reason why it doesn't look big is that they made the engine really compact, and it's not that heavy.
  9. Re: W16
    Very correct, here's the inside of it:
  10. Re: W16
    The reason why it looks so narrow, like a V-engine, is because VW made an exeptional job of making this engine as compact and space-saving as possible. It is also very light, for a 4-turbo W16. It also incorporates the latest variable valve timing technology. A work of art.
  11. Re: W16
    Beeeeautiful!!
  12. Re: W16
    it truely is a work of art, its very compact.
  13. Re: W16
    They are some niiice pictures especially that middle one.
  14. Re: W16
    Variable valve timing? They put everything they got on this project! Damn, this will be a real piece of supercar.
