WEIGHT VERY WRONG! its 1670kg, not 670kg!!
Discussion in '2001 B.Engineering Edonis' started by SpyderMan!, Nov 7, 2002.
  1. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    the car would fly with a power to weight like that!!
  2. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    errm...no, the weight is correct, check the edinos website.
  3. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    WHat website? And if so.. why the hell doesn't that thing fly?
  4. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    Do you mean "Weight's wrong it's 1671 kg not 671kg"
    Your'e still one number off
  5. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    Edinos? It's supposed to be edonis! Well, whatever, 671 kilos is an unreal stat.
  6. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    The mass of the Edonis is 1480kg, according to September 2002 Evo Magazine, who did an acceleration and top speed comparison with the McLaren F1. The Edonis got beaten in all acceleration tests and top speed for that matter because it had a problem with it- at a festival a few weeks before the test, a journo did a dozen standing starts which caused the clutch plate to be clamped to the flywheel, so the tester could not use the clutch too hard.
  7. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    Its probably right.
  8. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    uhh im pretty sure 1671 kg doesnt = 1479 lbs not mentioning 1kg=2.5lbs (roughly)
  9. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    The Prototype had a weight of 670 kg.,
    but because of the byers needs it would weight more.
    Imagine a Bugatti V12, almost 700 bhp and a weight of 670 kg.
    That is something that belongs on Le Mans.
  10. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    The weight on the Prodction car is 1300kg. This figure sounds more realistic.
  11. Re: WEIGHT VERY WRONG! its 1670kg, not 670kg!!
    e
