Wiking
Discussion in 'Trucks and Motorcycles' started by CitroenSM, Aug 29, 2004.
  1. Some pictures and technical data on the Swedish motorcycle Wiking.
    Engine: Straight in-line 4-cylinder, 4-stroke, air cooled entirely in aluminum. Pushrods and two stainless steel valves per cylinder. Oil capacity 3.5 l
    Bore/stroke: 85.7/80 mm
    Displacement: 1,845 cm3
    Compression: 7.5:1
    Effect: 48hp (35KW)/3,000 rpm
    Torque: 127 Nm/2,000-2,500 rpm
    Carburation: WEBER 34 ICH carburator
    Electrical system: 12 V, 28 Ah battery, generator output 384 W, BOSCH ignition with breaker-points. Electrical starter
    Transmission: 4 speed gearbox, universal shaft drive and dry clutch
    Chassis: Frame in welded steel pipe 30x3 mm and seamless steel pipe 42x4 mm
    Suspension: Front telescope, twin KONI dampers at rear
    Brakes: Single disc brake at front, drum brake at rear
    Wheels: Wire with AVON Gangster 130-90 H16
    Seat height: 780 mm
    Wheelbase: 1,750 mm
    Steering angle: 32 degrees
    Offset: 150 mm
    Fuel tank capacity: 18 litres
    Weight ready to drive: 320 kg
    Colours: Classic Dark Green, Classic Dark Red, Classic Dark Blue or special order
    Performance: Top speed in excess of 175 km/h
  2. Do you ride it around, hang out in bars and hassle shop keeps?
  3. If you think that's fun, I guess you do.
  4. Wow, that is a work of art. Finest non custom bike I have seen!
  5. #5 CitroenSM, Aug 29, 2004
  6. Interesting i have never heard of this beauty
  7. very nice bike<A BORDER="0" HREF="http://www.supercars.net/emoticons.html"><IMG BORDER="0" SRC="http://speed.supercars.net/pitlane/emoticons/wink.gif"></A> very nice design too<A BORDER="0" HREF="http://www.supercars.net/emoticons.html"><IMG BORDER="0" SRC="http://speed.supercars.net/pitlane/emoticons/wink.gif"></A>
  8. it looks nice
  9. If you're into cruisers, it would be cool to have something so unique.
  10. Isn't that a Volvo based motor?
    Anyway - it is sold in the US as a Dakota-Indian.
  11. Jesus that is beautiful.
  12. Yes, I belive it is.
  13. To bad American Indian died again.
  14. looks nice and all but not really my thing.
    48hp..320kg's...
    Although you'd probably slice a car in half if you ran into one.
