200 hp fuel burner from factory isnt bad
Discussion in '2002 Honda Civic Type-R' started by HooPoo, Aug 9, 2002.
  1. Re: 200 hp fuel burner from factory isnt bad
    another reason would be that the v-tec engine really lacks grunt in the lower rpm range, until the high range cam profile kicks in, v-tec doesnt really peform well, power to weight, aerodynamics and the gear ratio also have a lot to do with that, and yea, 200 bhp from a naturally aspirated inline 4 isnt bad at all
  2. Re: 200 hp fuel burner from factory isnt bad
    that's why it's a mix of both sporty and economic cuz in normal driving u use a lower RPM so it will feel like a econome car, but when racing u use a higer rpm then u will feel the power of a sports car
  3. Re: 200 hp fuel burner from factory isnt bad
    hmm its 200hp at the flywheel, not at the wheels, so i would definetly expect a huge decrease in measured hp at the wheels. The RSX type S is rated at 200hp and Import Tuner tested it and it only registered at around 165.
  4. Re: 200 hp fuel burner from factory isnt bad
    This is true with every car. No one said it had 200 hp at the wheels.
  5. Re: 200 hp fuel burner from factory isnt bad
    Fuel burner? what the #$%#.
  6. Re: 200 hp fuel burner from factory isnt bad
    Well, it does burn fuel . . .
  7. Re: 200 hp fuel burner from factory isnt bad
    you're a dumbass if you think the type R is meant to be a daily driver, the interior is loud, and its not ergonomical, its for hardcore autocrossers, thats why it weighs a lot less than the rest of them, despite having a bigger engine
