Highland.
Discussion in 'Trucks and Motorcycles' started by CitroenSM, Sep 4, 2004.
  1. #1 CitroenSM, Sep 4, 2004
    some pics and specs on a fantastic Swedish offroad bike.
    Technical Data Outback/Motard/Allroad:
    Engine: 936 cc, four-stroke DOHC, liquid-cooled, 60-degree V-twin, 4 valves per cylinder, 10:1 compression
    Engine lubrication: Wet sump, double filter, pressure pump to crank, cams and gearbox
    Power output: 62,5 kW (85 hp) at 6000 rpm and max. torque 104 Nm at 4000 rpm (tuning kit is available)
    Bore/stroke: 95/66 mm
    Injection/ignition: Highland/SCS Sweden. Integrated engine management system with ignition coils fitted directly on the spark plugs
    Starter: Electric
    Electrical system: 12 V, SEM 310 W, 12 Ah battery
    Transmission: 6-speed gearbox, separately lubricated mult disk clutch, Regina X-ring chain
    Brakes, front: 320 mm Brembo floating disk, double piston calipper
    Brakes, rear: 240 mm Brembo floating calipper
    Front fork: 48 mm USD WP or 50 mm Marzocchi. 280 mm spring travel, adjustable compression and rebound
    Shock absorber: WP or Öhlins, 300 mm spring travel, adjustable stiffness, compression and rebound
    Frame and swing arm: Rectangular section, CrMo steel and aluminium
    Wheels Outback: Pirelli MT 90 90/90-21" front and 150/70-18" rear, Excel aluminium rims with Talon hubs
    Wheels Motard: Pireli Super Corsa 120/70-17" front and 160/60-17" rear, Excel aluminium rims with Talon hubs
    Wheels Allroad: Pireli MT 90 Scorpion 100/90-19" front and 150/70-17" rear, Excel aluminium rims with Talon hubs
    Body: Termoplastic and Carbon. Silvergreymetallic, blackmetallic or yellowmetallic
    Seat height: Outback: 910 mm, Motard: 860 mm, Allroad: 840 mm
    Wheelbase: Outback: 1 530 mm, Motard: 1 490 mm, Allroad: 1 500 mm
    Steering angle: Outback: 26 degrees, Motard: 25 degrees,
    Allroad: 26 degrees
    Ground clearance: Outback: 300 mm, Motard: 270 mm, Allroad: 230 mm
    Fuel capacity: 20 litres
    Weight: Outback: 165 kg, Motard: 166 kg, Allroad: 164 kg
    Top speed: more than 200 km/h
    Note. Technical specifications may vary on different markets.
    Link: www.highland.se/home/
  2. Thank you i have been looking for info about thet bike
  3. You're welcome.
