Stats!!
Discussion in '1997 McLaren F1 GT' started by 1940 815, Mar 22, 2003.
  1. what are the stats for this monster?
  2. Re: Stats!!
    Nearly the same as the other Mc Larens!
  3. Re: Stats!!
    its just an aero switchout, nothing serious.
  4. Re: Stats!!
    It has 18" rims too. Not the 17" rims this website says it has. The GT is also 20kgs lighter than the standard F1.
  5. 1997 McLaren F1 GT
    Year 1997
    Make McLaren
    Model F1 GT
    Engine Location Mid
    Drive Type Rear Wheel
    Weight 1220 kg | 2690.1 lbs
    Performance
    0-60 mph 3.2 seconds.
    1/4 Mile 11.1 seconds.
    Top Speed 240 mph | 386.2 km/h
    Engine
    Engine Configuration V
    Cylinders 12
    Aspiration/Induction Normal
    Displacement 6064.00 cc | 370 cu in. | 6.1 L.
    Valves 48 valves.
    4 valves per cylinder.
    Valvetrain DOHC
    Horsepower 627.00 HP (461.5 KW) @ 7400.00 RPM
    Torque 480.00 Ft-Lbs (650.9 NM) @ 5600.00 RPM
    HP to Weight Ratio 4.3 LB / HP
    HP / Liter 102.8 BHP / Liter
    Bore 3.39 in | 86.1 mm. | 0.1 m.
    Stroke 3.43 in | 87.1 mm. | 0.1 m.
    Compression Ratio 10.5:1
    Transmission Information
    Gears 6
    Transmission Manual
    Final Drive 2.37:1
    Dimensions
    Seating Capacity 3
    Produced 3
    Exterior
    Length 194.001 in | 4927.6 mm.
    Width 76.001 in | 1930.4 mm.
    Height 47.001 in | 1193.8 mm.
    Wheelbase 107.001 in | 2717.8 mm.
    Front Track 63.801 in | 1620.5 mm.
    Rear Track 62.301 in | 1582.4 mm.
    Ground Clearance 70.001 mm | 2.8 in.
    Suspension
    Suspension Unassisted Rack & Pinion
    Brakes
    Front Brake Size 13.001 in | 330.2 mm.
    Rear Brake Size 12.001 in | 304.8 mm.
    Tires / Wheels
    Tires Goodyear Eagle F1
