Types of V8s
Discussion in 'Technical' started by Pimpmobile Caddy, Sep 7, 2004.
  1. I've read pages on flat-plane and cross-plane V8s, but I've never understood the difference.
    Can anybody easily explain the difference between the two?
  2. #2 V8Vantage, Sep 7, 2004
    On a flat plane crank, if you look down the length of the crank shaft it appears flat (it's is is one plane).
    On a cross plane crank the point at which the con-rods meet the crank are not all in the same plane, hance cross-plane crank.
    Look here: http://autozine.kyul.net/technical_school/engine/smooth4.htm
  3. Sorry, but I barely get it.
    But I'm guessing, is cross-plane crank the picture on the right and the flat-plane crank the picture on the left on those pictures above where it says "Flat-plane V8 for high performance cars"?
  4. The first pic, top left shows a flat plane and a cross plane side by side, it's not a great drawing but it's suposed to be in 3D.
    If you imagine a compass face, looking down the length of the cross plane crank in that first drawing, 1 is at North, 2 is at East, 3 is at West and 4 is ast South. On the flat plane crank, 1 is at North, 2 is at South, 3 is also at South and 4 is at North.
    The section titled 'Cross-plane V8' shows the end on view of a crank shaft (looking down the engine, the 'Y' shape is the cylinders above the crank). Notice how it looks like an 'X' - the crank has 2 'planes' 90 degrees to each other.
    The section titled 'Flat-plane V8 for high performance cars' shows an end on view of a flat plane crank, notice how it looks 'flat' end on, only one plane.
  5. #5 V8Vantage, Sep 7, 2004
    There is a 3D rendered drawing of flat plane vs cross plane on this site that might be easier to understand.
    http://www.e31.net/engines_e.html
    Scroll down to V8 engines.
  6. If you look down the length of the crank from the front, one will look like this '-', the other will look like this '+'.
  7. wouldnt flat planes cranks have less Torque but be able to rev higher?
  8. they'd have less smooth power delivery and rev higher because of decreased rotating weight
  9. Now I get it.
    But cross-planes need balancers, right?
  10. A flat plane crank also gives a better exhaust tuning, increasing the power a few percent by increaseing volumetric efficiency.
