WANNA SEE A FAST STOCK UTE?
Discussion in '1999 HSV Maloo' started by FORDFORD, Jan 21, 2003.
  1. #1 FORDFORD, Jan 21, 2003
    Engine Type Boss 290 - High Performance 5.4L DOHC V8 4V
    Max. Power 290kW@5,500rpm
    Max. Torque 520Nm@4,500rpm
    Engine Size (cc) 5408
    Compression Ratio 10.5:1
    Bore x Stroke 90.2mm x 105.8mm
    Boss 290 Engine Components
    GT GT-P Pursuit
    Internally balanced crankshaft
    FPV High-Lift Inlet Camshaft (13mm lift)
    FPV High-Lift Exhaust Camshaft (12mm lift)
    FPV High-Compression Pistons and Piston Ring Pack
    FPV Valves, Valve Springs and Roller Finger Followers
    75mm High Flow Throttle Body
    FPV High-Flow Air Intake System
    FPV Stainless Steel Fabricated Exhaust Headers
    FPV High-Rise Long Runner Intake Manifold
    Sweet CAr the new FORD pursuit ute!
    i got this info from www.fordperformancevehicles.com.au
  2. Re: WANNA SEE A FAST STOCK UTE?
    Okay i'm looking..............................all I can see is specs...so where is the fast stock ute?
  3. Re: WANNA SEE A FAST STOCK UTE?
    i reckon, i thought there was going to be links
  4. Re: WANNA SEE A FAST STOCK UTE?
    gooood u guys just demand everything dont you :p. here they are
  5. Re: WANNA SEE A FAST STOCK UTE?
    well here it is....
  6. Re: WANNA SEE A FAST STOCK UTE?
    LMAO!!! but its a ford and all fords are gay including this one
  7. Re: WANNA SEE A FAST STOCK UTE?
    yeah that is now, but what about in '99? yeah that shut you up!!!
  8. Re: WANNA SEE A FAST STOCK UTE?
    umm yeah i shutup since i cant read what u type befroe you send it dickhead? that shut you up. or maybe you cant read what im typing
  9. Re: WANNA SEE A FAST STOCK UTE?
    its a broader statement... pursuits r way beta than maloo
