Wrong rpmŽs !!Please, read the real specs here¡¡
Discussion in '1994 BMW 850 CSi' started by Juancho, Aug 9, 2002.
  1. It doesnŽt have 5300 rpmŽs it has 600-6400 rpm (depending on gear)
    Check the real eng data:Engine Data
    Displacement 5576 cc
    Cylinders12, V-engine 60°
    Compression 9.8:1
    Stroke / Bore 80mm / 86mm
    Firing order 1-7-5-11-3-9-6-12-2-8-4-10
    Valve diameter Intake: 42mm / outlet: 36mm
    Valve stroke intake/outlet: 11mm
    max. Power bhp / kW 380 / 280 at 5300 rpm
    max. torque 550 Nm at 4000 rpm
    max. rpm 6000-6400 rpm (depending on gear)
    rpm in neutral rpm750 rpm
  2. #2 BMWs R 4 me, Mar 27, 2003
    Re: Wrong rpm}s !!Please, read the real specs here¡¡
    i think is means 380hp @ 5300rpm, wat ur talking about is the redline,
    they do have the stats wrong aswell, it has 380hp, not 372hp like alot think, have a look at www.bmwinfo.com if want reasurance
  3. Re: Wrong rpm}s !!Please, read the real specs here¡¡
    -1 if i could
  4. Re: Wrong rpm}s !!Please, read the real specs here¡¡
    Way off 550 hp ouch dream/
  5. Re: Wrong rpm}s !!Please, read the real specs here¡¡
    Sexy car.
  6. Re: Wrong rpm}s !!Please, read the real specs here¡¡
    I dont trust bmwinfo.com either tho. Thier specs are wrong on my car, unless my manual lies to me.
  7. Re: Wrong rpmŽs !!Please, read the real specs here¡¡
    You guys did notice that, this engine is a derivative of the McLaren F1 engine rite?
    What impresses me on this car, is the torque! I want it soooo bad!
  8. Re: Wrong rpmŽs !!Please, read the real specs here¡¡
    this has SOHC. do you mean the f1's engine is based on this or what?
