Post #1 Mon, Oct 15, 6:48 AM |
jumpman23
Senior Member - 370
---- Specifications ---- Engine: 6 liter V12 Weight 3737 lbs Aspiration: natural Torque: 420 lb-ft @ 5750 rpm HP: 510 hp @ 6500 rpm HP/Weight -- HP/Liter: 85 hp per liter 0-62 mph: 4.3 seconds Top Speed: 191 mph
Aston Martin DBS Specification
Body Two-door coupe body style with 2+0 seating Bonded aluminium VH structure Aluminium, magnesium alloy and carbon-fibre composite body Extruded aluminium door side-impact beams High Intensity Discharge (HID) headlamps (main beam) LED rear lamps and side repeaters
Engine All-alloy, quad overhead camshaft, 48-valve, 5935cc V12. Compression ratio 10.9:1 Front-mid mounted engine, rear-wheel drive Fully catalysed stainless steel exhaust system with active bypass valves Max power: 380kW (510bhp/517 PS) at 6500rpm Max torque: 570Nm (420 lb.ft) at 5750rpm Acceleration: 0-100km/h (0-62mph) in 4.3 seconds Max speed: 302km/h (191mph)
Transmission Rear-mid mounted, six-speed manual gearbox Alloy torque tube with carbon fibre propeller shaft Limited-slip differential Final-drive ratio 3.71:1
Wheels and Tyres Front: 8.5 x 20 Pirelli P Zero 245/35 Rear: 11 x 20 Pirelli P Zero 295/30
Steering Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock-to-lock. Column tilt and reach adjustment
Suspension Front: Independent double wishbone incorporating anti-dive geometry, coil springs, anti-roll bare and monotube adaptive dampers Rear: Independent double wishbones with anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube adaptive dampers Adaptive Damping System (ADS) with Track mode
Brakes Front: Ventilated carbon ceramic discs, 398mm diameter with six-piston calipers Rear: Ventilated carbon ceramic discs, 360mm diameter with four-piston calipers Dynamic Stability Control (DSC) with Track mode Anti-lock Braking System (ABS) Electronic Brakeforce Distribution (EBD) Emergency Brake Assist (EBA) Traction control
Dimensions
Length: 4721mm (185.9) Wheelbase: 2740mm (107.9) Width: 1905mm (75) (exc. Mirrors) 2060mm (81.1) (inc. Mirrors) Fuel tank capacity: 78 litres (17.2 Imp.galls, 20.5 US galls) Height: 1280mm (50.4) Weight: 1695kg (3737lb)
Interior Semi-aniline leather and Alcantara interior. Matrix alloy facia trim and Iridium Silver centre console finish. Carbon fibre door trims and door pulls. Auto-dimming rear-view mirror & garage door opener (USA & Canada only). Sports seats with ten-way electric adjustment, including height, tilt and lumbar. Memory seats & exterior mirrors (three positions). Dual-stage driver/passenger front airbags. Side airbags (Sports seats only). Heated seats (Sports seats only). Heated rear screen. Automatic temperature control. Organic Electroluminescent (OEL) displays. Trip computer. Cruise control. Hard Disk Drive (HDD) satellite navigation system1,2. Bluetooth telephone preparation1. Powerfold exterior mirrors. Front and rear parking sensors. Tyre-pressure monitoring1. Alarm and immobiliser. Remote-control central door locking and boot release. Battery disconnect switch. Battery conditioner. Tracking device (UK only). Boot-mounted umbrella.
In-Car Entertainment Aston Martin 700W Premium Audio System with Dolby® Pro Logic II® MP3 player connectivity
Options Lightweight seats with six-way adjustment, including front and rear height adjust (Does not include side airbags or heated seats feature. Not available in USA or Canada) 20 alloy wheels with graphite finish Satellite radio system (USA only) Piano Black facia trim and centre console finish Leather storage saddle Personalised sill plaques Auto-dimming interior rear-view mirror1 Auto-dimming interior rear-view mirror with garage door opener (Europe only) Alarm upgrade (volumetric and tilt sensor) Tracking device3 First-aid kit Ashtray and cigar lighter
*1 Not available in all markets *2 Includes Traffic Messaging Channel (TMC) in Continental Europe *3 Complies with UK Thatcham Category 5 requirements. Excludes subscription. Standard in UK.
Post #2 Wed, Jul 2, 1:41 PM |
MB E430
New User - 51
anyone know about 1/4 mile and 0-100? it would be nice to know =]
Posted: Today |
Superbot
Posted: Today |
Superbot
| All Forums > 2008 Aston Martin DBS > Specs. > Post Reply |
