1 2 [Last >>]
All Forums > 2009 Hennessey Venom GT > LOL! @ Pushrod Activated OHV, 2 Valves per Cyl > Post Reply
Post #1 Mon, Nov 19, 1:18 AM
CitroenSM
Foose fan - 34503
They still build cars with this stone age technology?
Imagen how much power you could get out of it win 4 valves per cyl and twin overhead cams.
"Formula 1 is all about the car, Here it's all about the racing"
(\__/)
( o.O)
(")_(")
Edited by CitroenSM - Mon, Nov 19, 1:18 AM
Post #2 Mon, Nov 19, 1:41 AM
sixspeedfirebird
Supercar Messi - 20905
Imagine how much heavier and more expensive it'd be.
fivespeedturbogolf
F50 > F40
Post #3 Mon, Nov 19, 2:06 AM
CitroenSM
Foose fan - 34503
Quote from sixspeedfirebird
Not much heavier or much more expensive.
(\__/)
( o.O)
(")_(")
Edited by CitroenSM - Mon, Nov 19, 2:06 AM
Post #4 Mon, Nov 19, 3:47 AM
disord3r
38.593484ms - 17345
effyoo
Post #5 Mon, Nov 19, 7:02 AM
BenFenner
Supercar Messiah - 2556
Not only heavier and more expensive, but the block would be much taller as well. For all my love of DOHC engines, you can't deny pushrods have their benefits.
Ben Fenner is secure in his sexual orientation, which makes him a little bit better than most guys.
-CMG
I sincerely hope you're sitting back there saying, "Haha, look at all this wacky shit I'm saying! They really think I'm a pedophile!" rather than actually meaning it.
-bucknutz
Post #6 Mon, Nov 19, 7:44 AM
confusedshus
Supercar Messiah - 15007
Quote from disord3r
I think after S8 is must be not easy to drive some right hand drive manual supercar, full with manometers inside
Post #7 Mon, Nov 19, 7:44 AM
Atomic2
BANNED - 17944
way to fit right in here in the indies
Member of CHUPA
Post #8 Mon, Nov 19, 8:26 AM
ETB4U
Supercar Messiah - 1684
Quote from CitroenSM
Didn't OHV come after OHC? Didn't OHV defeat pretty much every OHC engine in the GT1 class in the ALMS, and is doing very well in the LeMans? Don't top fuel cars run OHV motors that are pushing 8,000HP?
Post #9 Mon, Nov 19, 8:52 PM
ElStiesen
Supercar Messiah - 1051
With 20 additional valves? :D
Post #10 Mon, Nov 19, 9:07 PM
CitroenSM
Foose fan - 34503
Quote from ETB4U
Well, Pushrods and two valves per cylindre still is an old technology that most sportcar manufacturers stopped using decades ago.
(\__/)
( o.O)
(")_(")
Edited by CitroenSM - Mon, Nov 19, 11:22 PM
Post #11 Tue, Nov 20, 12:07 AM
CitroenSM
Foose fan - 34503
Quote from BenFenner
Example:
Porsche M80 engine (V10)(used in the 2005 Carrera GT)
DOHC
Capacity : 5.7litres
Power : 605bhp @ 8,000rpm
Torque : 435lbf·ft @ 5,750rpm
Weight : 472lb
Dodge SRT-10 engine (V10)(used in the 2006 Dodge Viper)
pushrod OHV
Capacity : 8.3litres
Power : 510bhp @ 5,600rpm
Torque : 535lbf·ft @ 4,600rpm
Weight : 650lb
(\__/)
( o.O)
(")_(")
Post #12 Tue, Nov 20, 2:43 AM
KARASAWA40
New User - 30
Yes, and those guys aren't going any faster.
And where did you get that weight from? The Viper's V-10 is more like 550lbs. Even the later GTS engines weighed 614-636 lbs according to Dodge.
Here's another comparison, and remember Turbo's add weight
2007 Saleen S7 Twin Turbo Engine
Engine type Turbocharged 90° V-8, alum block/heads
Valvetrain OHV, 2 valves/cyl
Displacement 426.6 cu in / 6991 cc
Compression ratio 11.0:1
Power (SAE net) 750 hp @ 6300 rpm
Torque (SAE net) 700 lb-ft @ 4800 rpm
Redline 6500 rpm
Weight: 440 lbs
Source Motortrend
Post #13 Tue, Nov 20, 5:14 AM
dysfunctional
Supercar Guru - 868
Love the way you avoid answering the question about which came first. lol. If OHV is stoneage, then does that make DOHC "PRECAMBRIAN"? that really shows your ignorance. You would be better off saying that OHV is not your preference, than trying to insult its age, while backing something even older.
Just because alot of manufactures prefer one type of engine over another, doesn't make the other choice wrong. Same argument can be had with supercharger Vs turbocharger.
The Viper engine works well, is relatively cheap to maintain, is very reliable, and is easily tuned for insane power outputs.
Post #14 Tue, Nov 20, 11:53 AM
WhiteChocolateWorld
Supercar Messiah - 40519
Example:
DOHC
Weight : 472lb
pushrod OHV
Weight : 650lb
Isn't the viper v-10 like a 10 year old truck engine though? Might be better to compare to a more recently engineered one.
This is for Chris Draper:
A boot for Christmas.
Post #15 Tue, Nov 20, 12:31 PM
CitroenSM
Foose fan - 34503
Quote from dysfunctional
Pushrods and two valves per cylindre is stonage.
(\__/)
( o.O)
(")_(")
Post #16 Tue, Nov 20, 12:34 PM
CitroenSM
Foose fan - 34503
Quote from WhiteChocolateWorld
That's true it is, But it's still in use in new cars.
(\__/)
( o.O)
(")_(")
Post #17 Tue, Nov 20, 5:12 PM
ETB4U
Again, apparently its not a bad thing since they owned the T1 class in LeMans, and are in the fastest drag racers.
Post #18 Tue, Nov 20, 6:43 PM
Password please
Supercar Messiah - 6408
I don't think it really matters, as long as it gets the job done. And it should, afterall it's kinda like the concept behind the Tommy Kiara ZZII.....though not AWD.
(insert witty innuendo here)
Post #19 Tue, Nov 20, 7:34 PM
arnulfoes
Supercar Messiah - 1081
True but if you have tons of power from that insane V10 Engine use the engineering on suspension , transmission, or aerodynamic.
You will have the best car on earth , just by mixing the most powerfull engine (American OHV) and the best Engineering in suspension,tranny and that sh¡t in this case from Lotus , which is pretty good. So shut the &%$& up about saying that OHV is stonage , if american cars can't beat the euro ones is just because that American makers have not been working in Suspension and Transmission Tech ... and It looks like they just started with this Concept....
Post #20 Tue, Nov 20, 9:51 PM
Peter Von Schnitzel
New User - 1
The fact is that both pushrods AND overhead cams have their advantages, whether it's expense and packaging or efficiency etc. There's no right or wrong just personal preference. Me personally I'd go the overhead cams....
Post #21 Wed, Nov 21, 1:45 AM
CitroenSM
Foose fan - 34503
Quote from arnulfoes
Pushrods is stoneage and I'm suprised that they don't get more out of those huge engines seeing other car makers get the same or even more HP out of smaller engines, But one thing is for sure and that is that they sure put out an awesome amount of torque.
I never said anything about American cars not being able to beat European cars.
(\__/)
( o.O)
(")_(")
Post #22 Wed, Nov 21, 3:53 AM
ETB4U
Mercedes is stoneage, I guess they are junk too.
Post #23 Wed, Nov 21, 4:59 AM
CitroenSM
Foose fan - 34503
Quote from ETB4U
Engines using pushrods and two valves per cylinder are stone age no matter in what car the sit and I never said that any car was junk.
Why is it that some people always take other peoples opinions as a personal insult?
(\__/)
( o.O)
(")_(")
Edited by CitroenSM - Wed, Nov 21, 5:00 AM
Post #24 Thu, Nov 22, 10:02 PM
ETB4U
Actually, I was just pointing out someones idiotic comment.
Post #25 Fri, Nov 23, 7:16 AM
anmathur
New User - 2
aye pushrods are stoneage
"Bottles are for babies real men get blown"-NYMC
tuned turbo
Posted: Today
Superbot
Posted: Today
Superbot
1 2 [Newer >>]
